    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 22.1k Views 3 Watching
      I just uploaded another calendarfetcher.js to dropbox which corrects the timezone adjustment for daylight/std switch
      I was using the local system time instead of the calendar event start time to compare offsets with the rule created time
        I like how it behaves now… we are both currently on DST, you switch the daylight 1st (Oct 25), and the events when system is on my timezone, change, and then we change later to daylight (Nov 1), and then we are back on the same adjustment again and the event times adjust again correctly…
          SwissChemist
          Wow, that looks great! Thanks very much for your endurance!
          There is only that persistent ‘3-weekly whole day’ problem. It’s still one day too late. Most probably that’s so difficult, as it is a user defined interval, something strange seems to bring the parser to a wrong date…
          For testing, I have added a 3-daily event. This shows correct start/end…
          But the rest is great! Thanks very much!!!
            sdetweil @SwissChemist
            @SwissChemist check the end date in your cal entry it was set for the next day.
            2 -day event
              SwissChemist
              All whole day events start at the right day and end one day later. There is no difference in the calendar file, whether it is a weekly, 2-weekly or 3-weekly event.
              That’s why I do not understand, why weeklies and 2-weeklies are shown correctly and the 3-weekly is shown one day too late…
              S 2 Replies Last reply
                @SwissChemist but, whole day events are defined as starting and ending on the SAME day.
                  @SwissChemist yeh, that 3-weekly whole day event seems to cause a problem in the rule handler…
                  for THAT rule, it returns the repeating day as the 1st of the 2, (the last of the 2 for the others)
                  but if u take off the ;BYDAY=TH
                  is works properly… (and gives the thrusday date)
                  so, some bug in the rrule module… (not our code)
                  that is also the only weekly whole day rule you have which has a ByDay set.
                    SwissChemist @sdetweil
                    As I wondered if the format of an 3-weekly event in ical has an issue, I set up a 3-weekly event in Google calendar and compared the files:
                    BEGIN:VEVENT
                    DTSTART;VALUE=DATE:20201005
                    DTEND;VALUE=DATE:20201006
                    RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=MO
                    DTSTAMP:20201005T195008Z
                    UID:835F136F-35A4-44C6-AA16-481F02E5A2D1
                    CREATED:20201005T120626Z
                    DESCRIPTION:
                    LAST-MODIFIED:20201005T120626Z
                    SEQUENCE:0
                    STATUS:CONFIRMED
                    SUMMARY:3-weekly whole day test
                    TRANSP:OPAQUE
                    END:VEVENT
                    Event has been set to 5th of October and DTEND is also one day later than DTSTART for a whole-day-event and it also shows a BYDAY, that means it’s absolutely identical to the ical file…
                      @SwissChemist like I said, bug in the repeating rule processor, RRULE. not our code.
                      Remove the byday, or the second day
                        Sorry for asking:
                        If I would import a calendar file from a text file, it would be easy to do the correction (change DTEND or remove BYDAY) in any text editor.
                        But how to proceed if I directly import data from *.ics link? Is there any ‘hack’ I could apply?
                        Thanks very much for your patience… All other data are really great now! And somehow I rely on a 3-weekly whole day, as we use to have 3-week iterations in our SCRUM process…
                          @SwissChemist you could create a batch script, run off cron, or started w pm2 (and use sleep to wait)
                          curl to download the ics,
                          sed to fix the file,
                          and put it into the calendar module folder, and
                          config mm to use it from there
                            SwissChemist
                            Thanks very much for your help! I highly appreciate it!
                              @SwissChemist my pleasure… here is how I config MM to use your file
                              (note my mm is on a different port)
                                          url: "http://localhost:8090/modules/default/calendar/school-timetable.ics"
                                SwissChemist
                                Thanks for the example. Looks like a next project for me… :thumbs_up:
                                  @SwissChemist
                                  could look something like this
                                  #!/bin/bash
                                  fn=somecal.ics
                                  while true
                                    do
                                        # get the file from server
                                        curl -sL  url_of_remote_ics  >$fn
                                        # remove the trailing byday=??(end of line), file inline, so changed
                                        sed -i -e "s/;BYDAY=.*$//g" $fn
                                       # copy the modified file to the calendar folder
                                        cp $fn ~/MagicMirror/modules/default/calendar
                                       # sleep til next cycle
                                        sleep ??? (seconds til next curl)
                                     done
                                  have to make this executable with chmod +x script_filename
                                  then
                                  pm2 start script_filename
                                  pm2 save
                                  if you use a json config file ui can give a pretty name of the script… see the installers/pm2_magicmirror.json
                                  pm2 start jsonfile
                                  pm2 save
                                    @SwissChemist I submitted this issue to the RRULE repo
                                    https://github.com/jakubroztocil/rrule/issues/426
                                      Wow, thank you so much for your great support!
                                        @sdetweil This morning we switched from DST to STD time. No issue at all with the calendar, everything works fine!
                                        Again, thanks very much for your support!
                                          @SwissChemist nice, thanks for the update
                                            A Former User
                                            • 2 / 3
