    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 22.1k Views 3 Watching
      SwissChemist @sdetweil
      As I wondered if the format of an 3-weekly event in ical has an issue, I set up a 3-weekly event in Google calendar and compared the files:
      BEGIN:VEVENT
      DTSTART;VALUE=DATE:20201005
      DTEND;VALUE=DATE:20201006
      RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=MO
      DTSTAMP:20201005T195008Z
      UID:835F136F-35A4-44C6-AA16-481F02E5A2D1
      CREATED:20201005T120626Z
      DESCRIPTION:
      LAST-MODIFIED:20201005T120626Z
      SEQUENCE:0
      STATUS:CONFIRMED
      SUMMARY:3-weekly whole day test
      TRANSP:OPAQUE
      END:VEVENT
      Event has been set to 5th of October and DTEND is also one day later than DTSTART for a whole-day-event and it also shows a BYDAY, that means it’s absolutely identical to the ical file…
        sdetweil @SwissChemist
        @SwissChemist like I said, bug in the repeating rule processor, RRULE. not our code.
        Remove the byday, or the second day
          Sorry for asking:
          If I would import a calendar file from a text file, it would be easy to do the correction (change DTEND or remove BYDAY) in any text editor.
          But how to proceed if I directly import data from *.ics link? Is there any ‘hack’ I could apply?
          Thanks very much for your patience… All other data are really great now! And somehow I rely on a 3-weekly whole day, as we use to have 3-week iterations in our SCRUM process…
            @SwissChemist you could create a batch script, run off cron, or started w pm2 (and use sleep to wait)
            curl to download the ics,
            sed to fix the file,
            and put it into the calendar module folder, and
            config mm to use it from there
              SwissChemist
              Thanks very much for your help! I highly appreciate it!
                @SwissChemist my pleasure… here is how I config MM to use your file
                (note my mm is on a different port)
                            url: "http://localhost:8090/modules/default/calendar/school-timetable.ics"
                  SwissChemist
                  Thanks for the example. Looks like a next project for me… :thumbs_up:
                    @SwissChemist
                    could look something like this
                    #!/bin/bash
                    fn=somecal.ics
                    while true
                      do
                          # get the file from server
                          curl -sL  url_of_remote_ics  >$fn
                          # remove the trailing byday=??(end of line), file inline, so changed
                          sed -i -e "s/;BYDAY=.*$//g" $fn
                         # copy the modified file to the calendar folder
                          cp $fn ~/MagicMirror/modules/default/calendar
                         # sleep til next cycle
                          sleep ??? (seconds til next curl)
                       done
                    have to make this executable with chmod +x script_filename
                    then
                    pm2 start script_filename
                    pm2 save
                    if you use a json config file ui can give a pretty name of the script… see the installers/pm2_magicmirror.json
                    pm2 start jsonfile
                    pm2 save
                      @SwissChemist I submitted this issue to the RRULE repo
                      https://github.com/jakubroztocil/rrule/issues/426
                      S 2 Replies Last reply
                        Wow, thank you so much for your great support!
                          @sdetweil This morning we switched from DST to STD time. No issue at all with the calendar, everything works fine!
                          Again, thanks very much for your support!
                            @SwissChemist nice, thanks for the update
                              A Former User
                                A Former User
                                @hango: yes that why i have planned to coding mine…
                                Calendar default module is really so bugy for me …
                                sample :
                                0|MagicMirror  | [2020-10-25 21:17:41.162] [LOG]    Use existing calendar fetcher for url: https://calendar.google.com/calendar/ical/XXXX.ics
                                0|MagicMirror  | [2020-10-25 21:17:41.164] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
                                0|MagicMirror  | [2020-10-25 21:17:41.715] [INFO]   Calendar-Fetcher: Broadcasting 5 events.
                                and some timethere is 3 broadcasts … result 2 or 3 updates on mirror
                                I don’t know really what they do with this modules… and I will NOT correct it !
                                In all case, it’s horrible
                                  sdetweil @Guest
                                  @hango have fun. there are 3 libraries below the mm code. all broken or in disagreement over the format of the date and time. and windows is a whole nother mess
                                  why I work my a… off for you … I begin to wonder.
                                  2.11 might work for you but it doesn’t for others. and I didn’t start the changes.
                                  • 3 / 3
