    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 18.6k Views 3 Watching
      sdetweil
      yeh, that whole day thing… the spec says its whole day in the timezone where the computer is.
      but the ical converter still adjusts it to UTC. (all parsed events are in UTC)
      3-weekly 13-14 is completely missing (should be 1.Okt)
      can’t be cause u asked for WEdnesdays
      BEGIN:VEVENT
      CREATED:20200928T173050Z
      DTEND;VALUE=DATE:20201002
      DTSTAMP:20200928T182733Z
      DTSTART;VALUE=DATE:20201001
      LAST-MODIFIED:20200928T182732Z
      RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=WE  < ----
      SEQUENCE:0
      SUMMARY:3-weekly whole day
      UID:E2C82F47-1E0F-4FD0-93C4-746B2D53488B
      URL;VALUE=URI:
      END:VEVENT
      so , this repeating event might start on Oct 1, but thats a thursday, so will not be shown
      but later, Starting with the 3-weekly whole day 22.Okt (should be 21.Okt),
      starts on 21+1 days from today 00:00:00 Oct 21, and ends on Oct 22
      this is a fix in the ical parser… so, it will take time to get out…
        sdetweil
        can we try another quick fix?
        in calendar.js
        				// Define second, minute, hour, and day variables
        				var oneSecond = 1000; // 1,000 milliseconds
        				var oneMinute = oneSecond * 60;
        				var oneHour = oneMinute * 60;
        				var oneDay = oneHour * 24;
        				if (event.fullDayEvent) {
        					//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 one the next day
        					//event.endDate -= oneSecond;   < ---- comment out this one line
          SwissChemist @sdetweil
          maybe you expected already that now the endTime of each whole day event is shown one day too late. Without that fix, it has been correct.
          Regarding the ‘3-weekly whole day’ you gave me a perfect hint: As it is a user configured interval, you have to take care that begin of the event and day of the week you select as interval correspond. So if you configure it wrong, corresponding event will obviously not be shown, as you explained perfectly from your code analysis…
            I would not mind to see 23:59 as end of a whole day event, but it would also be fine for me to see the day where it starts again…
              sdetweil @SwissChemist
              @SwissChemist finding an acceptable “end” marker for “full day” event is challenging.
              it certainly ends when the next day starts.
                @SwissChemist can u look at this, your cal, in your timezone, 2.13 no modifications
                showEnd:true,
                maximumEntries:25,
                  SwissChemist
                  It’s getting better and better, great!
                  The only event, which is not correct yet, ist the 3-weekly 13-14. This should be in 21 days (Oct 22nd), exactly like the 3-weekly whole day. The following ones could be better controlled in an absolute time format…
                    @SwissChemist no… that cal entry says wednesdays, so the 21st, rule wins on exact days, start/end win on time
                    BEGIN:VEVENT
                    CREATED:20200928T173453Z
                    DTEND;TZID=Europe/Zurich:20201001T140000
                    DTSTAMP:20200928T182743Z
                    DTSTART;TZID=Europe/Zurich:20201001T130000
                    LAST-MODIFIED:20200928T182742Z
                    RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=WE  < -------
                    SEQUENCE:0
                    SUMMARY:3-weekly 13-14
                    UID:A7C8DBD0-0AA9-468B-A3F8-A5F97B797C11
                    URL;VALUE=URI:
                    END:VEVENT
                      SwissChemist
                      Ok, then it’s my error again. In the meantime I have corrected my calendar entry. Would you need a new calenendar export, or would you like to send me your fix to test it here?
                        @SwissChemist install/upgrade to 2.13, should fix it
                        I changed cal entry to TH, now shows 21 days, on the 22nd
                        • 6
                        • 2 / 6
