    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 21.3k Views 3 Watching
      sdetweil @SwissChemist
      @SwissChemist finding an acceptable “end” marker for “full day” event is challenging.
      it certainly ends when the next day starts.
        @SwissChemist can u look at this, your cal, in your timezone, 2.13 no modifications
        showEnd:true,
        maximumEntries:25,
          SwissChemist
          It’s getting better and better, great!
          The only event, which is not correct yet, ist the 3-weekly 13-14. This should be in 21 days (Oct 22nd), exactly like the 3-weekly whole day. The following ones could be better controlled in an absolute time format…
            @SwissChemist no… that cal entry says wednesdays, so the 21st, rule wins on exact days, start/end win on time
            BEGIN:VEVENT
            CREATED:20200928T173453Z
            DTEND;TZID=Europe/Zurich:20201001T140000
            DTSTAMP:20200928T182743Z
            DTSTART;TZID=Europe/Zurich:20201001T130000
            LAST-MODIFIED:20200928T182742Z
            RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=WE  < -------
            SEQUENCE:0
            SUMMARY:3-weekly 13-14
            UID:A7C8DBD0-0AA9-468B-A3F8-A5F97B797C11
            URL;VALUE=URI:
            END:VEVENT
              SwissChemist
              Ok, then it’s my error again. In the meantime I have corrected my calendar entry. Would you need a new calenendar export, or would you like to send me your fix to test it here?
                @SwissChemist install/upgrade to 2.13, should fix it
                I changed cal entry to TH, now shows 21 days, on the 22nd
                  SwissChemist
                  now I have corrected my calender entry, but I still cannot see same date for ‘3-weekly whole day’ and ‘3-weekly 13-14’.
                  Do you see same date for these events?
                  Any idea what I do wrong? Thx very much!
                    @SwissChemist what is your config for these entries, so I get the start formatting the same
                    never mind, copied from first entry
                      @SwissChemist yeh, I can see the same thing, actually there is a bigger problem… see the time switch standard to daylight
                      something happens , they go from start and end on same day to start one day end the next
                      weekly whole day does, 6th, 13, 20, 26?? 11/2
                      3 weekly happens around that same time, the actual clock is 10-22:22:00:00z
                      but the whole day things look weird… start on one day, and on the next… is that 1 day or 2?
                      all of the whole day events are '2 days actually, start on one day, end on the next
                      one thing on the 3-weekly whole day, you have TH set as the day, if u remove that it works… the rule processor
                      returns a different day depending.
                      will have to examine
                      so, something about the tz switch has messed this up… thanks for great testcase
                        @sdetweil i think I have a test fix, incuding the time correction over dst/std time shift
                        your timezone, all cal entries for whole day changed to 1 day (the 1st of the two listed)
                          SwissChemist @sdetweil
                          I am currently not sure how this will look like after changing from DST(UTC+2) to STD time(UTC+1).
                          For sure this will happen on sunday, 25th of October. That’s why whole day events starting on 26th look differently.
                          But how should it look like today? Oct 26th 01:00 - Oct 27th 00:59???
                            @SwissChemist install 2.13
                            and replace the ~/MagicMirror/modules/default/calendar/calendarfetcher.js
                            with this
                            https://www.dropbox.com/s/t7m1f49kvv3x2b1/calendarfetcher.js?dl=0
                            save the old one
                            it should correct dst/std time changes
                              3-weekly whole day now shows Okt 23, but it should be Okt 22
                              As I have seen in the calendar file, switching from DST to STD time is correctly defined for last Sunday in October, that is 25th of October. So this should not influence an event on 22nd of October…
                              Regarding events after switching from DST to STD time, I don’t have a clue, as I am not a dev, just a little experienced in testing…
                              I tried to understand the calendar file. As far as I have seen, you have only the date for whole day events (without any time):
                              BEGIN:VEVENT
                              CREATED:20201001T205859Z
                              DTEND;VALUE=DATE:20201023
                              DTSTAMP:20201001T205900Z
                              DTSTART;VALUE=DATE:20201022
                              LAST-MODIFIED:20201001T205859Z
                              RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=TH
                              SEQUENCE:1
                              SUMMARY:3-weekly whole day
                              UID:D718FE41-FF1B-43F6-9442-E9E43A41CCF0
                              URL;VALUE=URI:
                              END:VEVENT
                              In this case DTSTART is 20201022 and DTEND is 20201023.
                              For whole day events, can’t you simply set:
                              ‘Begin’ to value of DTSTART 00:00 and
                              ‘End’ to value of DTEND - 1day 23:59? (just as ical most probably uses 24:00 and that’s one day later)
                              Maybe it’s not as simple as I assume, otherwise you would have tried that already…
                              As we currently have TZOFFSET+0200 and switch to TZOFFSET+0100, I would rather expect that we see current events (planned after 25th Oct) on the monitor 1 hour too late.
                              So that’s why I currently would rather expect:
                              Oct 27th 01:00 - Oct 28th 00:59 for weekly whole day after switching to STD time instead of
                              Oct 26th 23:00 - Oct 27th 22:59
                              But as I mentioned before, maybe everything is much more complicated than I ever can imagine…
                                @SwissChemist your whole day event starts on one day, and ends on another
                                make up your mind…lol
                                I changed all the whole day DTEND to the same date as the DTSTART
                                  @SwissChemist if it were easy!!!
                                  the rule processor has a bug w timezones
                                  and apparently with multiple whole day events, and with dst/std adjustment
                                  and the calendar parser is not ours, and the rule processor is not ours,
                                  and we are split into get dates to show and show dates… show dates(calendar.js) doesn’t know anything about the cal entry. it’s just gets a list of start and end times, in utc time
                                    I just uploaded another calendarfetcher.js to dropbox which corrects the timezone adjustment for daylight/std switch
                                    I was using the local system time instead of the calendar event start time to compare offsets with the rule created time
                                      I like how it behaves now… we are both currently on DST, you switch the daylight 1st (Oct 25), and the events when system is on my timezone, change, and then we change later to daylight (Nov 1), and then we are back on the same adjustment again and the event times adjust again correctly…
                                        SwissChemist
                                        Wow, that looks great! Thanks very much for your endurance!
                                        There is only that persistent ‘3-weekly whole day’ problem. It’s still one day too late. Most probably that’s so difficult, as it is a user defined interval, something strange seems to bring the parser to a wrong date…
                                        For testing, I have added a 3-daily event. This shows correct start/end…
                                        But the rest is great! Thanks very much!!!
                                          @SwissChemist check the end date in your cal entry it was set for the next day.
                                          2 -day event
                                            SwissChemist
                                            All whole day events start at the right day and end one day later. There is no difference in the calendar file, whether it is a weekly, 2-weekly or 3-weekly event.
                                            That’s why I do not understand, why weeklies and 2-weeklies are shown correctly and the 3-weekly is shown one day too late…
                                            • 2 / 3
