    MMM-Calendar always shows 23:59 if showEndTime: True
    51 Posts 4 Posters 18.6k Views 3 Watching
      SwissChemist
      You are right, now in summer, we are GMT+1, in winter it’s GMT+2…
        @SwissChemist
        no the one I am fighting from Australia
        meeting at 09/28/20, 08:30
        utc is 09/27/20, 22:30
        rule detemines today is valid DATE
        takes todays date 09/28, with yesterdays time 22:30
        oops…
          @sdetweil so, your 1st entry is confusing… label is
          SUMMARY:Monthly 17-18
          but the cal entry says
          DTSTART;TZID=Europe/Zurich:20201002T170000, Oct 02, 1700 local, 1500 utz
            sdetweil
            also, showEnd is a pain… technically the clock is day:00:00 to day 23:59 as 23:59+1 is 24:00/00:00 which is the next day
            so, what do you think we should be showing there…
              sdetweil @SwissChemist
              @SwissChemist want to try a fix for me…
              edited: changed added line
              edit the ~/MagicMirror/modules/default/calendar/calendarfetcher.js
              find this (approx line 240) and add the one line listed below
              						// Loop through the set of date entries to see which recurrences should be added to our event list.
              						for (let d in dates) {
              							const date = dates[d];
              							// ical.js started returning recurrences and exdates as ISOStrings without time information.
              							// .toISOString().substring(0,10) is the method they use to calculate keys, so we'll do the same
              							// (see https://github.com/peterbraden/ical.js/pull/84 )
              							const dateKey = date.toISOString().substring(0, 10);
              							let curEvent = event;
              							let showRecurrence = true;
              							let duration = 0;
              							startDate = moment(date);
              							duration = parseInt(moment(curEvent.end).format("x")) - parseInt(moment(curEvent.start).format("x")) // --- add this line
              in your timezone (mine is Sep 28, 17:15)
                SwissChemist
                Hello Sam,
                thanks very much for your great support.
                Good news is that the endTime issue is solved now!
                Nevertheless with recurring whole day events, the following entries are not correct yet:
                3-weekly 13-14 is completely missing (should be 1.Okt)
                Starting with the 3-weekly whole day 22.Okt (should be 21.Okt), every following ‘whole day meeting’ is shown one day too late.
                You can easily see that even on your picture, as e.g. the 3-weekly whole day and the 3-weekly 13-14 should always take place at the same date.
                Even on your picture this is not the case… monthly whole day is shown in 3 days, monthly 17-18 is shown in 4 days.
                Once more, thanks for your great support so far!
                ![0_1601412306493_MagicMirror_200929.JPG](Uploading 100%)
                  sdetweil
                  yeh, that whole day thing… the spec says its whole day in the timezone where the computer is.
                  but the ical converter still adjusts it to UTC. (all parsed events are in UTC)
                  can’t be cause u asked for WEdnesdays
                  BEGIN:VEVENT
                  CREATED:20200928T173050Z
                  DTEND;VALUE=DATE:20201002
                  DTSTAMP:20200928T182733Z
                  DTSTART;VALUE=DATE:20201001
                  LAST-MODIFIED:20200928T182732Z
                  RRULE:FREQ=WEEKLY;INTERVAL=3;BYDAY=WE  < ----
                  SEQUENCE:0
                  SUMMARY:3-weekly whole day
                  UID:E2C82F47-1E0F-4FD0-93C4-746B2D53488B
                  URL;VALUE=URI:
                  END:VEVENT
                  so , this repeating event might start on Oct 1, but thats a thursday, so will not be shown
                  but later, Starting with the 3-weekly whole day 22.Okt (should be 21.Okt),
                  starts on 21+1 days from today 00:00:00 Oct 21, and ends on Oct 22
                  this is a fix in the ical parser… so, it will take time to get out…
                    sdetweil
                    can we try another quick fix?
                    in calendar.js
                    				// Define second, minute, hour, and day variables
                    				var oneSecond = 1000; // 1,000 milliseconds
                    				var oneMinute = oneSecond * 60;
                    				var oneHour = oneMinute * 60;
                    				var oneDay = oneHour * 24;
                    				if (event.fullDayEvent) {
                    					//subtract one second so that fullDayEvents end at 23:59:59, and not at 0:00:00 one the next day
                    					//event.endDate -= oneSecond;   < ---- comment out this one line
                      SwissChemist @sdetweil
                      maybe you expected already that now the endTime of each whole day event is shown one day too late. Without that fix, it has been correct.
                      Regarding the ‘3-weekly whole day’ you gave me a perfect hint: As it is a user configured interval, you have to take care that begin of the event and day of the week you select as interval correspond. So if you configure it wrong, corresponding event will obviously not be shown, as you explained perfectly from your code analysis…
                        I would not mind to see 23:59 as end of a whole day event, but it would also be fine for me to see the day where it starts again…
                        • 6
                        • 4 / 6
