    MMM-NowPlayingOnSpotify stop working after v2.13 update
    46 Posts 3 Posters 20.1k Views 3 Watching
    • P Offline
      panos
      Hello.
      I get the following error since I updated to MM v2.13
      [0|mm     | [2020-10-03 19:55:18.881] [ERROR]
      0|mm     | Can’t retrieve current song. Reason:
      0|mm     | [2020-10-03 19:55:18.882] [ERROR]
      0|mm     | RequestError: Error: Client network socket disconnected before secure TLS connection was established
      0|mm     |     at new RequestError (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/errors.js:14:15)
      0|mm     |     at Request.plumbing.callback (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/plumbing.js:87:29)
      0|mm     |     at Request.RP$callback [as _callback] (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request-promise-core/lib/plumbing.js:46:31)
      0|mm     |     at self.callback (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:185:22)
      0|mm     |     at Request.emit (events.js:200:13)
      0|mm     |     at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-NowPlayingOnSpotify/node_modules/request/request.js:877:8)
      0|mm     |     at ClientRequest.emit (events.js:200:13)
      0|mm     |     at TLSSocket.socketErrorListener (_http_client.js:402:9)
      0|mm     |     at TLSSocket.emit (events.js:200:13)
      0|mm     |     at emitErrorNT (internal/streams/destroy.js:91:8) {
      0|mm     |   name: 'RequestError',
      0|mm     |   message: 'Error: Client network socket disconnected ' +
      0|mm     |     'before secure TLS connection was ' +
      0|mm     |     'established',
      0|mm     |   cause: Error: Client network socket disconnected before secure TLS connection was established
      0|mm     |       at connResetException (internal/errors.js:559:14)
      0|mm     |       at TLSSocket.onConnectEnd (_tls_wrap.js:1355:19)
      0|mm     |       at Object.onceWrapper (events.js:288:20)
      0|mm     |       at TLSSocket.emit (events.js:205:15)
      0|mm     |       at endReadableNT (_stream_readable.js:1154:12)
      0|mm     |       at processTicksAndRejections (internal/process/task_queues.js:84:9) {
      0|mm     |     code: 'ECONNRESET',
      0|mm     |     path: null,
      0|mm     |     host: 'api.spotify.com',
      0|mm     |     port: 443,
      0|mm     |     localAddress: undefined
      0|mm     |   },
      0|mm     |   error: Error: Client network socket disconnected before secure TLS connection was established
      0|mm     |     path: null,
      0|mm     |     port: 443,
      0|mm     |   },
      0|mm     |   options: {
      0|mm     |     url: 'https://api.spotify.com/v1/me/player',
      0|mm     |     headers: {
      0|mm     |       Authorization: 'Bearer ' +
      0|mm     |         'BQBRDGEfWRoLJxBqiqioyoWh4GE5glEZQtZKAmgwYj8PiRhKDh9l796Ehlo7URvaB-_22gnk2Ybr7OxENlnlZS9S247mYnDa7-yzRnw0B6jug8-arHzcWMUr8xViOkVJMsKGink3bHhdiNmezkfFeA'
      0|mm     |     },
      0|mm     |     json: true,
      0|mm     |     method: 'GET',
      0|mm     |     callback: [Function: RP$callback],
      0|mm     |     transform: undefined,
      0|mm     |     simple: true,
      0|mm     |     resolveWithFullResponse: false,
      0|mm     |     transform2xxOnly: false
      0|mm     |   },
      0|mm     |   response: undefined
      0|mm     | }](link url)
      Any suggestions?
      • C Offline
        chassain 0
        hello,
        I don’t know about spotify but with update 2.13 i need to reload modules needing npm install or some dependances.
          sdetweil @chassain 0
          @chassain-0 IF you have to reload depenedencies on MM, then you MUST reload them in each module that uses a package.json
          that is why I built the upgrade_script… nobody knows… just use the script…
          see here https://github.com/sdetweil/MagicMirror_scripts
          • P Offline
            panos
            Hello.
            I have completely uninstall the module and install it again. Still no luck.
            All other modules works as they should.
              sdetweil @panos
              @panos when was the last time you used it?
              • C Offline
                chassain 0 @sdetweil
                i know…i take your great script at each update. i did this tonight…After a black screen, i had to reload modules (google photos, customer-flight, etc which need more than a npm)
                  @chassain-0 please show me the errors so I can fix them
                  • C Offline
                    @sdetweil too late…all is ok now…and i delete log…for next time :)
                      @chassain-0 i know…
                      • P Offline
                        panos @sdetweil
                        I don’t remember exactly, but I think that it was working 3-4 days ago
                        • C Offline
                          chassain 0
                          i have spotify in a raspberry with a old update…I’m going to check if script is ok with this module
                          • C Offline
                            chassain 0
                            doing test run processing complete for all modules in first
                              sdetweil @panos
                              @panos and if you use spotify client on some other device it works ok?
                              • P Offline
                                panos @chassain 0
                                @chassain-0
                                I don’t know why this happens then.
                                I run npm install on more time and rerun the authentication process via browser. (In order to update the token)
                                Still the same error.
                                • C Offline
                                  chassain 0 @panos
                                  @panos i’m running the script for this raspberry…wait and i give you the result
                                  • P Offline
                                    panos @sdetweil
                                    Yes. I’m able to listen via Spotify app on both mobile/desktop
                                    • C Offline
                                      chassain 0
                                      always in running
                                      • P Offline
                                        panos @chassain 0
                                        @chassain-0
                                        I update mine via “git pull && npm install” command
                                        • C Offline
                                          chassain 0 @panos
                                          @panos
                                          use sdetweil script…it’s better
                                          • C Offline
                                            what i need to do after ?
                                            • 2 / 3
