MMM-NowPlayingOnSpotify stop working after v2.13 update
@sdetweil the errors…same with the script
[2020-10-03 21:04:52.359] [ERROR] [31mWARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'winston'[39m [31mRequire stack:[39m [31m- /home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js[39m [31m- /home/pi/MagicMirror/modules/MMM-Provider-JSON/node_helper.js[39m [31m- /home/pi/MagicMirror/js/app.js[39m [31m- /home/pi/MagicMirror/js/electron.js[39m [31m- /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js[39m [31m- [39m [2020-10-03 21:04:52.396] [ERROR] App threw an error during load [2020-10-03 21:04:52.397] [ERROR] Error: Cannot find module 'winston' Require stack: - /home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js - /home/pi/MagicMirror/modules/MMM-Provider-JSON/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at Function.Module._load (internal/modules/cjs/loader.js:531:27) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js:1:46) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) [2020-10-03 21:04:52.398] [ERROR] Whoops! There was an uncaught exception... [2020-10-03 21:04:52.399] [ERROR] Error: Cannot find module 'winston' Require stack: - /home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js - /home/pi/MagicMirror/modules/MMM-Provider-JSON/node_helper.js - /home/pi/MagicMirror/js/app.js - /home/pi/MagicMirror/js/electron.js - /home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js - at Module._resolveFilename (internal/modules/cjs/loader.js:627:15) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16) at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29) at Function.Module._load (internal/modules/cjs/loader.js:531:27) at Module.require (internal/modules/cjs/loader.js:685:19) at require (internal/modules/cjs/helpers.js:16:16) at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js:1:46) at Module._compile (internal/modules/cjs/loader.js:786:30) at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10) at Module.load (internal/modules/cjs/loader.js:645:32) { code: 'MODULE_NOT_FOUND', requireStack: [ '/home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js', '/home/pi/MagicMirror/modules/MMM-Provider-JSON/node_helper.js', '/home/pi/MagicMirror/js/app.js', '/home/pi/MagicMirror/js/electron.js', '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js', undefined ] } [2020-10-03 21:04:52.404] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection? [2020-10-03 21:04:52.405] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues -
@chassain-0 could not find module winston
so npm install winston
@sdetweil yes. I do this and a lot of other dependances for this module
@chassain-0 what does that mean?
the error is clear
maybe have to install in module folder. means their package.json is bad
I have still no luck with NowPlayingOnSpotify.
Any suggestion would be much appreciated. -
@panos spotify is running with this version …sorry but you need to check your config
@panos send the config.js here
Sorry. I forget to put them when I’m removing sensitive data.
this is the correct config./* Magic Mirror Config Sample * * By Michael Teeuw http://michaelteeuw.nl * MIT Licensed. * * For more information how you can configurate this file * See https://github.com/MichMich/MagicMirror#configuration * */ var config = { address: "0.0.0.0", // Address to listen on, can be: // - "localhost", "127.0.0.1", "::1" to listen on loopback interface // - another specific IPv4/6 to listen on a specific interface // - "", "0.0.0.0", "::" to listen on any interface // Default, when address config is left out, is "localhost" port: 8080, ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "10.0.10.0/24", "10.0.50.0/24"], // Set [] to allow all IP addresses // or add a specific IPv4 of 192.168.1.5 : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.5"], // or IPv4 range of 192.168.3.0 --> 192.168.3.15 use CIDR format : // ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.3.0/28"], language: "en-gb", timeFormat: 24, units: "metric", modules: [ { module: "alert", config: { alert_effect: "flip" } }, { module: "updatenotification", position: "top_center" }, ..... { module: "MMM-NowPlayingOnSpotify", position: "top_left", config: { clientID: “a4r..54f" clientSecret: “e2...d3" accessToken: "BQD...95fmg", refreshToken: "AQAr....YXR3" } }, { module: "MMM-Remote-Control", // position: 'bottom_left', } ] }; /*************** DO NOT EDIT THE LINE BELOW ***************/ if (typeof module !== "undefined") {module.exports = config;} -
you have just forget comma for client id,clientsecret…
@chassain-0 I have edited my previews post.
