    MMM-NowPlayingOnSpotify stop working after v2.13 update
    46 Posts 3 Posters 24.3k Views 3 Watching
      panos @sdetweil
      @sdetweil the datetime is correct on my raspberry system
        chassain 0 @sdetweil
        @sdetweil the errors…same with the script
        [2020-10-03 21:04:52.359] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'winston'
        Require stack:
        - /home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js
        - /home/pi/MagicMirror/modules/MMM-Provider-JSON/node_helper.js
        [2020-10-03 21:04:52.396] [ERROR]  App threw an error during load
        [2020-10-03 21:04:52.397] [ERROR]  Error: Cannot find module 'winston'
        Require stack:
            at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
            at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
            at Function.Module._load (internal/modules/cjs/loader.js:531:27)
            at Module.require (internal/modules/cjs/loader.js:685:19)
            at require (internal/modules/cjs/helpers.js:16:16)
            at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js:1:46)
            at Module._compile (internal/modules/cjs/loader.js:786:30)
            at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
            at Module.load (internal/modules/cjs/loader.js:645:32)
        [2020-10-03 21:04:52.398] [ERROR]  Whoops! There was an uncaught exception...
        [2020-10-03 21:04:52.399] [ERROR]  Error: Cannot find module 'winston'
        Require stack:
            at Module.load (internal/modules/cjs/loader.js:645:32) {
          code: 'MODULE_NOT_FOUND',
          requireStack: [
            '/home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js',
            '/home/pi/MagicMirror/modules/MMM-Provider-JSON/node_helper.js',
            '/home/pi/MagicMirror/js/app.js',
            '/home/pi/MagicMirror/js/electron.js',
            '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
            undefined
        [2020-10-03 21:04:52.404] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
        [2020-10-03 21:04:52.405] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
          sdetweil @chassain 0
          @chassain-0 could not find module winston
          so npm install winston
            @sdetweil yes. I do this and a lot of other dependances for this module
              @chassain-0 what does that mean?
              the error is clear
              maybe have to install in module folder. means their package.json is bad
                panos
                I have still no luck with NowPlayingOnSpotify.
                Any suggestion would be much appreciated.
                C 2 Replies Last reply Reply Quote 0
                  chassain 0 @panos
                  @panos spotify is running with this version …sorry but you need to check your config
                    chassain 0 @panos
                    @panos send the config.js here
                      panos @chassain 0
                      @chassain-0
                      Sorry. I forget to put them when I’m removing sensitive data.
                      this is the correct config.
                      /* Magic Mirror Config Sample
                       * MIT Licensed.
                      var config = {
                      	address: "0.0.0.0", // Address to listen on, can be:
                      	port: 8080,
                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "10.0.10.0/24", "10.0.50.0/24"], // Set [] to allow all IP addresses
                      	language: "en-gb",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                      			alert_effect: "flip"
                      			module: "updatenotification",
                      			position: "top_center"
                      			module: "MMM-NowPlayingOnSpotify",
                      				clientID: “a4r..54f"
                      				clientSecret: “e2...d3"
                      				accessToken: "BQD...95fmg",
                      				refreshToken: "AQAr....YXR3"
                      			module: "MMM-Remote-Control",
                      //			position: 'bottom_left',
                        chassain 0
                        you have just forget comma for client id,clientsecret…
                          panos @chassain 0
                          @chassain-0 I have edited my previews post.
                            chassain 0 @panos
                            @panos i don’t see… in var config address i 'm using localhost…
                              panos @chassain 0
                              @chassain-0 I have configure it this way to have access remotely to MM using MMM-Remote-Control
                                chassain 0 @panos
                                @panos you have to work this module directly on the raspberry…check again
                                  panos
                                  The problem seems to be cached api.spotify.com IP address. flush dns servers records and works again.
                                  Thanks guys for your help
                                    sdetweil @panos
                                    @panos so, were you using pihole or something like that?
                                      panos @sdetweil
                                      @sdetweil yeah kind of. Although I have set api.spotify.com to be static for some reason. I haven’t had any issues until now. maybe something was changed on Spotify side.
                                      • 2 / 3
