    MMM-NowPlayingOnSpotify stop working after v2.13 update
    46 Posts 3 Posters 23.1k Views 3 Watching
      chassain 0
      always in running
        panos @chassain 0
        @chassain-0
        I update mine via “git pull && npm install” command
          chassain 0 @panos
          @panos
          use sdetweil script…it’s better
            chassain 0 @sdetweil
            what i need to do after ?
              panos @chassain 0
              @chassain-0 so the module can’t work because the request-promise-native package is deprecated?
                sdetweil @panos
                @panos no…deprecated means don’t use it new anymore, and plan to change now for any existing… will take a year or more to remove…
                  panos @sdetweil
                  @sdetweil ok I see, thanks.
                  So is there any workaround to make the module to work again?
                    chassain 0 @panos
                    @panos i’m waiting instructions to continue…If i do a restart mm i have a black screen
                      sdetweil @chassain 0
                      @chassain-0 @panos are your system clocks right?
                      looking thru the causes for the error…
                        chassain 0
                        i don’t know if git stash pop is necessary
                          panos
                          I haven’t had black screen once I updated to v2.13.
                          seems that only some modules need the “npm install” command
                            @chassain-0 well, you asked to save the changes… what are they and why? stash pop is the only way to get them back, but they might break other changes depending on what the changes are
                              sdetweil @panos
                              @panos if they have a package,json, you should npm install (what my script does)
                                panos @sdetweil
                                @sdetweil the datetime is correct on my raspberry system
                                  @sdetweil the errors…same with the script
                                  [2020-10-03 21:04:52.359] [ERROR]  WARNING! Could not load config file. Starting with default configuration. Error found: Error: Cannot find module 'winston'
                                  Require stack:
                                  - /home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js
                                  - /home/pi/MagicMirror/modules/MMM-Provider-JSON/node_helper.js
                                  [2020-10-03 21:04:52.396] [ERROR]  App threw an error during load
                                  [2020-10-03 21:04:52.397] [ERROR]  Error: Cannot find module 'winston'
                                  Require stack:
                                      at Module._resolveFilename (internal/modules/cjs/loader.js:627:15)
                                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/common/reset-search-paths.js:41:16)
                                      at Function.Module._resolveFilename (/home/pi/MagicMirror/node_modules/module-alias/index.js:49:29)
                                      at Function.Module._load (internal/modules/cjs/loader.js:531:27)
                                      at Module.require (internal/modules/cjs/loader.js:685:19)
                                      at require (internal/modules/cjs/helpers.js:16:16)
                                      at Object.<anonymous> (/home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js:1:46)
                                      at Module._compile (internal/modules/cjs/loader.js:786:30)
                                      at Object.Module._extensions..js (internal/modules/cjs/loader.js:798:10)
                                      at Module.load (internal/modules/cjs/loader.js:645:32)
                                  [2020-10-03 21:04:52.398] [ERROR]  Whoops! There was an uncaught exception...
                                  [2020-10-03 21:04:52.399] [ERROR]  Error: Cannot find module 'winston'
                                  Require stack:
                                      at Module.load (internal/modules/cjs/loader.js:645:32) {
                                    code: 'MODULE_NOT_FOUND',
                                    requireStack: [
                                      '/home/pi/MagicMirror/modules/MMM-FeedUtilities/LOG.js',
                                      '/home/pi/MagicMirror/modules/MMM-Provider-JSON/node_helper.js',
                                      '/home/pi/MagicMirror/js/app.js',
                                      '/home/pi/MagicMirror/js/electron.js',
                                      '/home/pi/MagicMirror/node_modules/electron/dist/resources/default_app.asar/main.js',
                                      undefined
                                  [2020-10-03 21:04:52.404] [ERROR]  MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                  [2020-10-03 21:04:52.405] [ERROR]  If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                    @chassain-0 could not find module winston
                                    so npm install winston
                                      @sdetweil yes. I do this and a lot of other dependances for this module
                                        @chassain-0 what does that mean?
                                        the error is clear
                                        maybe have to install in module folder. means their package.json is bad
                                          panos
                                          I have still no luck with NowPlayingOnSpotify.
                                          Any suggestion would be much appreciated.
                                          C 2 Replies Last reply Reply Quote 0
                                            chassain 0 @panos
                                            @panos spotify is running with this version …sorry but you need to check your config
                                            • 2 / 3
