    Stuck trying to sendSocketNotification from my node_helper
    4 Posts 2 Posters 752 Views 2 Watching
      seeshaughnessy
      I must be doing missing something obvious, but I’ve been at this forever. Sorry if the code looks rough, but I’m new to coding and still have some learning to do…
      I was able to get my requests just fine when I used axios and async/await (I’m most familiar with this library). I’m trying to convert the code to use the request library that’s built into Magic Mirror, but I can’t figure out what I’m doing wrong.
      I’m able to get the array I need with the request.get, but none of the code after my console.log('Result: ', result); // check seems to be working. I can’t log my filteredParcels, and the notification is not being sent.
      Am I missing something silly? Or is my whole concept incorrect?
      getOneTracker: function () {
          // Authenticate and get token
          var options = {
            uri: 'https://api.onetracker.app/auth/token',
            method: 'POST',
            json: {
              email: this.config.username,
              password: this.config.password,
          request(options, function (error, response, body) {
            if (!error && response.statusCode == 200) {
              const authToken = body.session.token;
              const options = {
                uri: 'https://api.onetracker.app/parcels',
                json: true,
                headers: {
                  'x-api-token': authToken,
              request.get(options, function (error, response, body) {
                  let result = body.parcels;
                  const filteredParcels = result.filter((parcel) => {
                    this.getDaysToReceive(parcel);
                  this.sendSocketNotification('ONETRACKER_RESULT', filteredParcels);
        // Returns days left until delivery, null if delivered 1+ days ago, and ? if delivery is unknown
        getDaysToReceive: function (parcel) {
          const parcelStatus = parcel.tracking_status;
          const parcelDate = parcel.tracking_time_estimated;
          const parcelDay = parcelDate.substr(8, 2); //Get day from tracking data
          var today = new Date().toString().substr(8, 2); //Get todays date
          const daysToDelivery = parcelDay - today;
          if (parcelStatus != 'delivered' && daysToDelivery < 0) return '?';
          if (parcelStatus != 'delivered' && daysToDelivery >= 0)
            return daysToDelivery;
          if (parcelStatus == 'delivered' && daysToDelivery == 0) return '0';
          return;
        sdetweil @seeshaughnessy
        @seeshaughnessy the problem is what the ‘this’ pointer points to
        inside the request callback, ‘this’ points to the request, NOT the node_helper data.
        this is why we assign ‘this’ to a variable ‘self’ BEFORE calling request, and then use self. inside the callback instead of this.
          seeshaughnessy
          Darnit, that makes total sense! Thank you!
            @seeshaughnessy you can continue to use axios. preferred as request has been depreciated.
            just add it to your package.json to get it loaded w your module
            # create package.json
            npm init -y
            # install a library and record it
            npm install axios --save
            in your module folder
