    Pi loses WiFi connection after a few hours
    rasberry pi 4wificonnection
    9 Posts 5 Posters 5.1k Views 5 Watching
      MajorC Project Sponsor
      Hello,
      my Raspberry Pi 4 (4GB) seems to lose the WiFi connection after a few hours (I can’t say exactly yet).
      Whereby this is not correct. The device still has the correct IP address. In the WiFi menu it is connected with the correct SSID. But I can’t ping a device in the network anymore. Also the Raspberry is not reachable from the network.
      Rebooting the Raspberry solves the problem immediately.
      Power Management: off is already set. What else can I do?
      • swvalentiS Offline
        swvalenti Project Sponsor
        Linux script that will check if the wifi on the pi is connected and reconnect if needed. This script is run from the pi. Typically you would set this up as a cron job that would run periodically (e.g. every 5 minutes). If the script detected the wifi was not connected it would attempt to reconnect.
        https://gist.github.com/mharizanov/5325450
          Thank you, at the moment I would like to find the problem. There are a couple of modules on the MM that are using the internet connection regularly. So there should be no need to disconnect.
          • H Offline
            heretodomagic
            @MajorC said in Pi loses WiFi connection after a few hours:
            I have the same issue except rebooting doesn’t correct the issue
              At the moment I am doing long term test. A have a new SD Card, with online running raspberry os on it. So far, after 24h the pi runs smoothly and the Wi-Fi is still working.
              Tomorrow I will install MM2 on the same card, to see what’s going on.
              What I need to know is, where to look if after installing MM2 the problems start?
              • jca2112J Offline
                jca2112
                I wanted to revive this topic, as I am having the same issue.
                After a day or two, the Raspberry Pi 3 B+ seems to lose it’s connection. I’m not able to connect to it via SSH, and the Weather module stops updating temp/forecast/etc. The news headline module and calendar module seem to continue to update, however.
                This problem goes away (temporarily) after a reboot.
                Looking at the error logs, I only see this:
                [ERROR] fatal: unable to access 'https://github.com/MichMich/MagicMirror.git/': Could not resolve host: github.com
                I’ve made sure the Pi is updated, and I’m able to ping sites (like github) after the reboot.
                Any ideas? I haven’t had any problems until the past month or two.
                • jca2112J Offline
                  jca2112
                  This Github post seems to describe the same (or similar) issue:
                  https://github.com/MichMich/MagicMirror/issues/218
                    sdetweil @jca2112
                    @jca2112 are you running pihole as an advert filter? seem to see this a lot with pihole servers…
                    i had a system that would lose connection almost daily… (over a years time)
                    finally installed a different network system… google wifi vs router and extenders…
                    wifi hub in same location as one of the prior extenders
                    haven’t had it fail since
                    jca2112J 1 Reply Last reply Reply Quote 0
                    • jca2112J Offline
                      jca2112 @sdetweil
                      @sdetweil said in Pi loses WiFi connection after a few hours:
                      Yes, I am running a pihole – thanks for suggesting that. (I should have mentioned it.) I’ve not had any issues with the magicmirror + pihole setup in the past, but just to make sure I whitelisted the magicmirror so it would bypass the pihole altogether. It didn’t seem to affect the problem, so I’m not sure that it is a factor.
