MM-concert-calendar
Hello,
I am trying to install the MM-concert-calendar module.
after runing query: https://api.songkick.com/api/3.0/search/locations.json?query=YOUR_CITY_HERE&apikey=YOUR_SONGKICK_API
i have this:{"resultsPage": {"status": "ok", "results": {"location": [{"city": {"lat": 49.1833, "lng": - 0.35, "country": {"displayName ":" France "}," displayName ":" Caen "}," metroArea ": {" lat ": 49.1833," lng ": - 0.35," country ": {" displayName ":" France "}," uri ":" http://www.songkick.com/metro_areas/28855-france-caen? utm_source=59898&utm_medium=partner "," displayName ":" Caen "," id ": 28855}}]}," perPage ": 50, "page": 1, "totalEntries": 1}}i open open concertcalendar.js but i don’t find the property named in the concertcalendar.js
:/* Magic Mirror * Module: ConcertCalendar * * By Marc Pratllusà https://github.com/muilpp * based on a Script from Benjamin Angst http://www.beny.ch * MIT Licensed. */ Module.register("concertcalendar",{ // Define module defaults defaults: { maximumArtist: 150, // Number of bands to check if they are on tour concertsPerPage: 8, updateInterval: 60 * 60 * 24 * 1000, // Once a day. paginationInterval: 20 * 1000, // Every twenty seconds. animationSpeed: 2000, fade: true, fadePoint: 0.25, // Start on 1/4th of the list. initialLoadDelay: 0, // start delay seconds. apiBase: 'http://localhost:8282/concerts', area: "28714", //your songkick area here (Barcelona, Spain by default) user: "",. //your lastfm username here titleReplace: { "Upcoming Concerts Calendar ": "" }, }, // Define required scripts. getStyles: function() { return ["concertcalendar.css", "font-awesome.css"]; }, // Define required scripts. getScripts: function() { return ["moment.js"]; }, // Define start sequence. start: function() { Log.info("Starting module: " + this.name); // Set locale. moment.locale(config.language); this.concerts = []; this.visibleConcerts = []; this.loaded = false; this.paginationTimer = null; this.paginationIndex = 0; this.scheduleUpdate(this.config.initialLoadDelay); this.paginationUpdate(); this.updateTimer = null; }, // Override dom generator. getDom: function() { var wrapper = document.createElement("div"); var table = document.createElement("table"); table.className = "small"; for (var t in this.visibleConcerts) { var concert = this.visibleConcerts[t]; var row = document.createElement("tr"); table.appendChild(row); var concertArtistCell = document.createElement("td"); concertArtistCell.className = "from"; concertArtistCell.innerHTML = concert.artist; row.appendChild(concertArtistCell); var concertCityCell = document.createElement("td"); concertCityCell.innerHTML = " - " + concert.city.trim()+", "; concertCityCell.className = "align-right trainto"; row.appendChild(concertCityCell); var concertDate = document.createElement("td"); concertDate.innerHTML = concert.concertDate; concertDate.className = "align-right trainto"; row.appendChild(concertDate); } return table; }, /* updateTimetable() * Calls processConcerts on succesfull response. */ updateTimetable: function() { var url = this.config.apiBase + this.getParams(); var self = this; var retry = true; var concertRequest = new XMLHttpRequest(); concertRequest.open("GET", url, true); concertRequest.onreadystatechange = function() { if (this.readyState === 4) { if (this.status === 200) { self.processConcerts(JSON.parse(this.response)); } else if (this.status === 401) { self.config.id = ""; self.updateDom(self.config.animationSpeed); Log.error(self.name + ": Incorrect, 401 reponse..."); retry = false; } else { Log.error(self.name + ": Could not load concerts."); } if (retry) { self.scheduleUpdate((self.loaded) ? -1 : self.config.retryDelay); } } }; concertRequest.send(); }, /* getParams(compliments) * Generates an url with api parameters based on the config. * * return String - URL params. */ getParams: function() { var params = "/"; params += this.config.area; params += "/" + this.config.user; params += "?limit=" + this.config.maximumArtist; return params; }, /* processConcerts(data) * Uses the received data to set the various values. * * argument data object - Weather information received form openweather.org. */ processConcerts: function(data) { this.concerts = []; data.forEach((concert) => { var city = concert.City.split(","); if (city.length > 0) { cityToAdd = city[0]; if (city[0].length > 9) cityToAdd = city[0].substring(0,9)+".."; artistToAdd = concert.Artist; if (artistToAdd.length > 10) artistToAdd = artistToAdd.substring(0,10)+".."; var date = new Date(concert.Date); this.concerts.push({ artist: artistToAdd.trim(), city: cityToAdd.trim(), concertDate: date.getDate()+"/"+(date.getMonth()+1) }); } }); this.loaded = true; concertsToShow = this.concerts.slice(0,this.config.concertsPerPage); this.visibleConcerts = this.visibleConcerts.concat(concertsToShow); this.updateDom(this.config.animationSpeed); }, paginate: function() { this.paginationIndex = this.paginationIndex + this.config.concertsPerPage; if (this.concerts.length > this.paginationIndex) { this.visibleConcerts = this.concerts.slice(this.paginationIndex, this.paginationIndex+this.config.concertsPerPage); } else { this.visibleConcerts = this.concerts.slice(0,this.config.concertsPerPage); this.paginationIndex = 0; } this.updateDom(this.config.animationSpeed); }, /* scheduleUpdate() * Schedule next update. * * argument delay number - Milliseconds before next update. If empty, this.config.updateInterval is used. */ scheduleUpdate: function(delay) { var nextLoad = this.config.updateInterval; if (typeof delay !== "undefined" && delay >= 0) { nextLoad = delay; } var self = this; clearTimeout(this.updateTimer); this.updateTimer = setTimeout(function() { self.updateTimetable(); }, nextLoad); }, paginationUpdate: function() { var self = this; setInterval(function() { self.paginate(); }, this.config.paginationInterval); }, });and add my username in the property right below it.
If not, is there a simpler module to have concerts close to home in France?
I tried with MMM-Events but my city, Caen in France (city of more than 100,000 inhabitants), is too small for the eventful API: on the eventfull website concerts are displayed but with the API concerts are not are not found, by contacting eventful I understood that I would have to buy an API which I do not want and moreover Eventful forgets a lot of concerts for my city.
Thank you for your help.
