    MMM-MQTTbridge doesn't seem to report USER_PRESENCE correctly?
    4 Posts 2 Posters 1.1k Views 2 Watching
    • F Offline
      fribse
      I can see that MMM-Remote-Control set’s the USER_PRESENCE depending on the state of the monitor.
      I try to interpret that to update the status of the switch in HomeAssistant by having it set up in the notiDictionary
      The config looks like this:
      var notiHook = [
          notiId: "USER_PRESENCE",
          notiPayload: [
              payloadValue: true,
              notiMqttCmd: ["SCREENON"]
              payloadValue: false,
              notiMqttCmd: ["SCREENOFF"]
      var notiMqttCommands = [
          commandId: "SCREENOFF",
          mqttTopic: "bathroom/mirror/monitor",
          mqttMsgPayload: "{'state':'OFF'}"
          commandId: "SCREENON",
          mqttMsgPayload: "{'state':'ON'}"
      module.exports = { notiHook, notiMqttCommands };
      The logs looks like this:
      0|mm     | [2020-10-16 09:44:34.089] [LOG]
      0|mm     | [MQTT bridge] NOTI->MQTT. Topic: bathroom/mirror/monitor, payload: false
      0|mm     | [2020-10-16 09:44:34.101] [LOG]
      0|mm     | Powering off HDMI
      0|mm     | [2020-10-16 09:44:34.102] [LOG]
      0|mm     | [2020-10-16 09:44:36.936] [LOG]
      0|mm     | [MQTT bridge] NOTI->MQTT. Topic: bathroom/mirror/monitor, payload: {"state":"ON"}
      0|mm     | [2020-10-16 09:44:37.793] [LOG]
      0|mm     | Powering on HDMI with preferred settings
      0|mm     | [2020-10-16 09:44:37.795] [LOG]
      So when it turns off, it doesn’t report state: off it just reports ‘false’ and it only reports state:on when it’s on.
      I do see the messages appear in the MQTT, but as they are incorrectly formatted, HA doesn’t update it properly.
      SergeS 1 Reply Last reply Reply Quote 0
      • SergeS Offline
        Serge @fribse
        @fribse please send here as well console log. Also, could you please wait and check wat is happening when FALSE is sent by user_presence for the second time.
        E.g. it would help full to see behaviour : false, true, … false
        • SergeS Offline
          Serge
          @fribse resolved on github, the reason is that for Boolean values the payloadValue should be set up as 1 or 0 for true/false.
          • F Offline
            fribse
            The config that works looks like this:
            var notiHook = [
                notiPayload: [
                    payloadValue: '1',
                    payloadValue: '0',
                mqttTopic: "state/bathroom/mirror/monitor",
                mqttMsgPayload: "OFF"
                mqttMsgPayload: "ON"
            Thankyou again for your excellent help and sharp eyes Serge!. :flexed_biceps: :heart_suit:
