    Auto power on and off
    14 Posts 10 Posters 9.7k Views 9 Watching
    • N
      natebrown
      Hi there,
      I was wondering if there was technology out there where i can set a timer to make the mirror turn on and off automatically at a specific time each day. I cant find anything. Does anyone else use something similar?
      • garblefluxG
        garbleflux Project Sponsor
        I use via crontab the CEC-function of the Monitor:
        turn on monitor weekdays 8 o clock:
        0 8 * * 1-5 echo “on 0” | cec-client -s -d 1 >/dev/null 2>&1
        turn on monitor on saturday & sunday 9.30 o clock:
        30 9 * * 0,6 echo “on 0” | cec-client -s -d 1 >/dev/null 2>&1
        turn off monitor daily at 20.30 o clock
        30 20 * * * echo ‘standby 0’ | cec-client -s -d 1 >/dev/null 2>&1
        this works like a charme since over one year
        regards Mike
        • thgmirrorT
          thgmirror
          @natebrown enter crontab -e at the prompt and insert the data garbieflux mentioned.
          If you struggle with the syntax, you can use several internet-pages to define the rules:
          https://crontab-generator.org/
          or
          https://crontab.guru/ for exapmle
          I use
          @reboot sudo sh -c ‘echo none > /sys/class/leds/led0/trigger’
          @reboot sudo sh -c ‘echo 0 > /sys/class/leds/led0/brightness’
          @reboot sudo sh -c ‘echo none > /sys/class/leds/led1/trigger’
          @reboot sudo sh -c ‘echo 0 > /sys/class/leds/led1/brightness’
          to turn off the LEDs at my RPI 3+
          Btw, an # at the beginning of the line marks it as a comment.
          Or use a time-switch to turn on and off the whole construction.
          Thomas
          • BKeyportB
            BKeyport Module Developer
            If you use a time switch to turn on and off the entire construction, you should still have a crontab to shut down the pi prior to shutting down the power, so you don’t corrupt your media.
            • thgmirrorT
              thgmirror
              Yes, @BKeyport idea is highly recommended:-)
              • E
                ember1205
                I have a WiFi plug that switches the device on at a specific time in the morning.
                I use a cron job entry to shut the Pi down at a specific time at night.
                I have the WiFi plug turn off at a specific time at night, five minutes after the time I’ve configured the cron job to shut the Pi down.
                There is also an IFTTT integration where you can have the shutdown script make a specific call to create a calendar entry on a Google calendar and IFTTT will pick up that entry and use it to trigger the power-off event for the plug. I used to do this until IFTTT changed their account structure and I’ve been moving away from using any of their integrations.
                • N
                  natebrown @garbleflux
                  @garbleflux
                  Thanks, so i want it to turn on at 6:30 every morning and turn off at 9 every night, If i copy and paste that into crontab -e, will that work? What is the exact code i need?
                  • H
                    hamid
                    I did not test with there are motion detectors that turn on the screen when moving the front screen does not know how it works
                    https://www.swedx.se/product_info.php?cPath=137_12800030&products_id=1955
                    rejasR 1 Reply Last reply Reply Quote 0
                    • T
                      TJuTZu
                      You can use also MMM-ModuleScheduler with MMM-Remote-Control to turn monitor on/off if you don’t need to turn off the whole system.
                      It works similar to crontab
                      Here is example from my mirror configuration
                            module: 'MMM-Remote-Control'
                            // uncomment the following line to show the URL of the remote control on the mirror
                            // , position: 'bottom_left'
                            // you can hide this module afterwards from the remote control itself
                              module: 'MMM-ModuleScheduler',
                                  notification_schedule: [
                                      // TURN THE MONITOR/SCREEN ON At 10:00
                                      {notification: 'REMOTE_ACTION', schedule: '00 10 * * *', payload: {action: "MONITORON"}},
                                      // TURN THE MONITOR/SCREEN OFF At 00:00
                                      {notification: 'REMOTE_ACTION', schedule: '00 00 * * *', payload: {action: "MONITOROFF"}}
                      • BKeyportB
                        If you wanna go down that path, there’s MMM-Remote-Control, too.
                        • rejasR
                          rejas Module Developer @hamid
                          @hamid you can use a standard webcam (like the pi cam or a playstation camera like I do) and my module https://github.com/rejas/MMM-MotionDetector to detect motion and turn your monitor off and on.
                            Socrates @BKeyport
                            @bkeyport said in Auto power on and off:
                            I was looking at the option of turning off the monitor instead the rpi.
                            I have the MMM-Remote-Control installed, but i dont see a way to turn off the monitor automatically, there’s an option to turn on and off the monitor and it works well, but how do i automate it?
                              sdetweil @Socrates
                              @socrates I use a webcam and turn off the monitor, motion turns it back on.
                              some use IR (PIR) sensors to detect people heat and turn on…
                                Socrates @sdetweil
                                @sdetweil Thank you. I have Home Assistant in place, the only gripe is that I wont have enough space between the mm frame and the outlet to shove another smart outlet. I guess i will need to replace the single gang smart outlet.
