    MMM-Carousel w/ Slide Navigation
    15 Posts 2 Posters 4.8k Views 3 Watching
      banbutcher @raf
      @raf
      if its not working after that, im afraid i dont know, sorry
      i dont know anything about ssh either :(
        raf
        @vondes
        have been on it for days even now at the moment and still nothing
          raf
          in the end this is my solution (don’t add keybindings)
                      module: 'MMM-Carousel',
                      position: 'bottom_bar', // Required only for navigation controls
                          transitionInterval: 0,
                          ignoreModules: ['clock', 'alert', 'MMM-GoogleAssistant',],
                          mode: 'slides',
                          showPageIndicators: true,
                          showPageControls: true,
                          slides: {
                              "Default": ['calendar', 'currentweather', 'MMM-Tools', 'newsfeed', 'MMM-TuyaSL', 'MMM-NowPlayingOnSpotify', 'weatherforecast',],
                              "Slide 2": ['newsfeed',],
                              "Slide 3": ['newsfeed',],
                              "Slide 4": ['newsfeed',],
                              "Slide 5": ['newsfeed',],
                          keyBindings: {
                              enabled: true,
                              map: {
                                  NextSlide: "ArrowRight",
                                  PrevSlide: "ArrowLeft",
                                  Slide0: "ArrowUp",
                                  Slide5: "ArrowDown",
                              mode: "DEFAULT"
            banbutcher
            glad to hear you figured it out, i know coming from a very limited knowledge base, trial and error was how i figured it out!
            when you say dont add key bindings do you mean the module MMM-Keybindings or the keyBindings in the carousel config?
              raf @banbutcher
              @banbutcher
              module installed (MMM-Keybindings) but not added in the config and it works (my knowledge is also very limited because I also have to figure everything out) I normally work in the concrete so that is something completely different huh
