Navigation
    • Search
    MMM-Telegram
    Troubleshooting
    • J
      James Farmer last edited by James Farmer
      @Bugsounet
      Hello,
      I’m having trouble this module to work,
      Instruction says
      Command /newbot, give a name to the bot created, give an username. username should end with bot. (e.g. MyMagicMirrorBot or mystupidslave-bot… )
      so i use example johnsmith for name and johnsmithmmbot for username.
                              disabled: false,
                              module: 'MMM-TelegramBot',
                              position: 'top_center',
                                      verbose: true,
                                      telegramAPIKey : 'mykey',
                                      allowedUser : ['johnsmith'], // This is NOT the username of bot.
      but i get error :
      [2020-11-02 13:21:06.815] [LOG] [TELBOT] ERROR {
      ok: false,
      error_code: 400,
      description: ‘Bad Request: chat_id is empty’
      I am not sure allowedUser is correct ?
      When i goto my Telegram bot, and type /mychatid, i get “You are not allowed to command me, ask admin”
      Thankyou
        A Former User last edited by
        @James-Farmer said in MMM-Telegram:
        allowedUser : [‘johnsmith’], // This is NOT the username of bot.
        Hi, i think you have make a mismake in your username.
        i think johnsmith is your pseudonym
        allowedUser is the real Telegram Username (your username start with an @)
        you can see your user name in your profil of Telegram application
        example: if you username is @johnsmith14586 so allowedUser: ['johnsmith14586'],
        • J
          @Bugsounet
          Hi, thanksyou for coming back to me, Sorry i couldn’t find Telegram username.
          So i look here
          I cant see any other username with @ only username of bot ?
          sorry if im being stupid.
            3 lines to the left of search > parameters > edit profils
            and you will see your username with @
            • J
              @Bugsounet I found it…!! and it is all now working
              Thankyou for the help.
