MMM-Awesome-Alexa isn't working
@sdetweil here are all the logs from the console:
main.js:487 Initializing MagicMirror. translator.js:129 Loading core translation file: translations/it.json translator.js:154 Loading core translation fallback file: translations/en.json loader.js:176 Load script: modules/default/alert//alert.js module.js:513 Module registered: alert loader.js:148 Bootstrapping module: alert loader.js:176 Load script: modules/default/alert/notificationFx.js loader.js:153 Scripts loaded for: alert loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css loader.js:195 Load stylesheet: vendor/css/font-awesome.css loader.js:155 Styles loaded for: alert translator.js:102 alert - Load translation fallback: translations/en.json /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure protocols.This exposes users of this app to unnecessary security risks. Consider loading the following resources over HTTPS or FTPS. - http://localhost:8080/css/main.css - http://localhost:8080/fonts/roboto.css - http://localhost:8080/socket.io/socket.io.js - http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js - http://localhost:8080/js/defaults.js - http://localhost:8080/config/config.js - http://localhost:8080/vendor/vendor.js - http://localhost:8080/modules/default/defaultmodules.js - http://localhost:8080/js/logger.js - http://localhost:8080/translations/translations.js - http://localhost:8080/js/translator.js - http://localhost:8080/js/class.js - http://localhost:8080/js/module.js - http://localhost:8080/js/loader.js - http://localhost:8080/js/socketclient.js - http://localhost:8080/js/main.js - http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2 - http://localhost:8080/translations/it.json - http://localhost:8080/translations/en.json - http://localhost:8080/modules/default/alert//alert.js - http://localhost:8080/modules/default/alert/notificationFx.js - http://localhost:8080/modules/default/alert/notificationFx.css - http://localhost:8080/vendor/css/font-awesome.css - http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css - http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css For more information and help, consult https://electronjs.org/docs/tutorial/security. This warning will not show up once the app is packaged. warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security Policy set or a policy with "unsafe-eval" enabled. This exposes users of this app to unnecessary security risks. For more information and help, consult https://electronjs.org/docs/tutorial/security. This warning will not show up once the app is packaged. (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 loader.js:157 Translations loaded for: alert loader.js:176 Load script: modules/default/updatenotification//updatenotification.js module.js:513 Module registered: updatenotification loader.js:148 Bootstrapping module: updatenotification loader.js:153 Scripts loaded for: updatenotification loader.js:155 Styles loaded for: updatenotification loader.js:157 Translations loaded for: updatenotification loader.js:176 Load script: modules/default/clock//clock.js module.js:513 Module registered: clock loader.js:148 Bootstrapping module: clock loader.js:176 Load script: vendor/node_modules/moment/min/moment-with-locales.js loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js loader.js:153 Scripts loaded for: clock loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css loader.js:155 Styles loaded for: clock loader.js:157 Translations loaded for: clock loader.js:176 Load script: modules/default/calendar//calendar.js module.js:513 Module registered: calendar loader.js:148 Bootstrapping module: calendar loader.js:236 File already loaded: moment.js loader.js:153 Scripts loaded for: calendar loader.js:195 Load stylesheet: modules/default/calendar/calendar.css loader.js:236 File already loaded: font-awesome.css loader.js:155 Styles loaded for: calendar loader.js:157 Translations loaded for: calendar loader.js:176 Load script: modules/default/compliments//compliments.js module.js:513 Module registered: compliments loader.js:148 Bootstrapping module: compliments loader.js:236 File already loaded: moment.js loader.js:153 Scripts loaded for: compliments loader.js:155 Styles loaded for: compliments loader.js:157 Translations loaded for: compliments loader.js:176 Load script: modules/default/currentweather//currentweather.js module.js:513 Module registered: currentweather loader.js:148 Bootstrapping module: currentweather loader.js:236 File already loaded: moment.js loader.js:153 Scripts loaded for: currentweather loader.js:195 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css loader.js:195 Load stylesheet: modules/default/currentweather/currentweather.css loader.js:155 Styles loaded for: currentweather loader.js:157 Translations loaded for: currentweather loader.js:176 Load script: modules/MMM-awesome-alexa//MMM-awesome-alexa.js module.js:513 Module registered: MMM-awesome-alexa loader.js:148 Bootstrapping module: MMM-awesome-alexa loader.js:153 Scripts loaded for: MMM-awesome-alexa loader.js:195 Load stylesheet: modules/MMM-awesome-alexa/styles/global.css loader.js:155 Styles loaded for: MMM-awesome-alexa loader.js:157 Translations loaded for: MMM-awesome-alexa loader.js:176 Load script: modules/default/weatherforecast//weatherforecast.js module.js:513 Module registered: weatherforecast loader.js:148 Bootstrapping module: weatherforecast loader.js:236 File already loaded: moment.js loader.js:153 Scripts loaded for: weatherforecast loader.js:236 File already loaded: weather-icons.css loader.js:195 Load stylesheet: modules/default/weatherforecast/weatherforecast.css loader.js:155 Styles loaded for: weatherforecast loader.js:157 Translations loaded for: weatherforecast loader.js:176 Load script: modules/default/newsfeed//newsfeed.js module.js:513 Module registered: newsfeed loader.js:148 Bootstrapping module: newsfeed loader.js:236 File already loaded: moment.js loader.js:153 Scripts loaded for: newsfeed loader.js:155 Styles loaded for: newsfeed loader.js:157 Translations loaded for: newsfeed loader.js:195 Load stylesheet: css/custom.css (index):1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled. loader.js:206 Error on loading stylesheet: css/custom.css stylesheet.onerror @ loader.js:206 alert.js:162 Starting module: alert updatenotification.js:19 Start updatenotification clock.js:46 Starting module: clock calendar.js:81 Starting module: calendar compliments.js:38 Starting module: compliments currentweather.js:97 Starting module: currentweather weatherforecast.js:87 Starting module: weatherforecast newsfeed.js:57 Starting module: newsfeed main.js:508 All modules started! module.js:199 currentweather is suspended. module.js:199 weatherforecast is suspended. MMM-awesome-alexa.js:1 MMM-awesome-alexa received a notification: idle - Payload: [object Object] api.openweathermap.org/data/2.5/forecast/daily?id=2525065&cnt=40&units=metric&lang=it&APPID=8dbb79dbda0a167be34484549a620503:1 Failed to load resource: the server responded with a status of 401 (Unauthorized) weatherforecast.js:261 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint. weatherRequest.onreadystatechange @ weatherforecast.js:261 (index):1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.The only place where the module is mentioned seems to be when a notification is sent to the module, which remains in idle
Here is a screen of just the errors and warnings
I have in fact one last idea to debug this, could you please send me your MMM-awesome-alexa folder with everything builded and working, in order to try it with my setup ?
@LukeTheWalker I am away doing some photography. will be back this weekend, and I will try to package up something
Thank you very much, anyway I am really thankful for all the time you spent trying to debug this with meReally looking forward this weekend, have some nice shots!
@sdetweil may I remind you of our discussion?
@LukeTheWalker thanks for the nudge
here is a link to the zip of the working MMM-awesome-alexa folder on my pi4.
@sdetweil update if interested, the problem was with the Bluetooth device I was using, switched to a usb to combo jack adaptor and now it work!
Any idea on how to play music since amazon music is locked ?
@LukeTheWalker far as I know, you cannot play music thru the awesome Alexa module.
