    MMM-Awesome-Alexa isn't working
    17 Posts 2 Posters 3.9k Views 2 Watching
      sdetweil @LukeTheWalker
      @LukeTheWalker when u start up mm, do you see any errors in the window where u do npm start, or if u use pm2,
      pm2 logs --lines=???
      where ??? is a number, default 15
      • L Offline
        LukeTheWalker
        @sdetweil here is the log from running npm start dev:
        pi@raspberrypi:~/MagicMirror $ npm start dev
        > magicmirror@2.13.0 start /home/pi/MagicMirror
        > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js "dev"
        [2020-11-09 22:20:24.369] [LOG]    Starting MagicMirror: v2.13.0
        [2020-11-09 22:20:24.382] [LOG]    Loading config ...
        [2020-11-09 22:20:24.393] [LOG]    Loading module helpers ...
        [2020-11-09 22:20:24.397] [LOG]    No helper found for module: alert.
        [2020-11-09 22:20:24.502] [LOG]    Initializing new module helper ...
        [2020-11-09 22:20:24.503] [LOG]    Module helper loaded: updatenotification
        [2020-11-09 22:20:24.505] [LOG]    No helper found for module: clock.
        [2020-11-09 22:20:25.317] [LOG]    Initializing new module helper ...
        [2020-11-09 22:20:25.318] [LOG]    Module helper loaded: calendar
        [2020-11-09 22:20:25.319] [LOG]    No helper found for module: compliments.
        [2020-11-09 22:20:25.321] [LOG]    No helper found for module: currentweather.
        [2020-11-09 22:20:27.118] [LOG]    Initializing new module helper ...
        [2020-11-09 22:20:27.119] [LOG]    Module helper loaded: MMM-awesome-alexa
        [2020-11-09 22:20:27.121] [LOG]    No helper found for module: weatherforecast.
        [2020-11-09 22:20:27.166] [LOG]    Initializing new module helper ...
        [2020-11-09 22:20:27.168] [LOG]    Module helper loaded: newsfeed
        [2020-11-09 22:20:27.169] [LOG]    All module helpers loaded.
        [2020-11-09 22:20:27.389] [LOG]    Starting server on port 8080 ...
        [2020-11-09 22:20:27.408] [LOG]    Server started ...
        [2020-11-09 22:20:27.410] [LOG]    Connecting socket for: updatenotification
        [2020-11-09 22:20:27.411] [LOG]    Connecting socket for: calendar
        [2020-11-09 22:20:27.412] [LOG]    Starting node helper for: calendar
        [2020-11-09 22:20:27.413] [LOG]    Connecting socket for: MMM-awesome-alexa
        [2020-11-09 22:20:27.415] [LOG]    Connecting socket for: newsfeed
        [2020-11-09 22:20:27.416] [LOG]    Starting node helper for: newsfeed
        [2020-11-09 22:20:27.417] [LOG]    Sockets connected & modules started ...
        [2020-11-09 22:20:27.614] [LOG]    Launching application.
        [2020-11-09 22:20:37.287] [LOG]    Create new calendar fetcher for url: http://localhost:8080/modules/calendars/526b2266ca404c95648812c17dcb716454dc7796f89c0581ae65ee9228174e55.ics - Interval: 300000
        [2020-11-09 22:20:37.316] [LOG]    Create new calendar fetcher for url: http://localhost:8080/modules/calendars/cea74d97bef3bf37890989ecc073ff23f172a87c372189a17ebacd5c694df2a7.ics - Interval: 300000
        [2020-11-09 22:20:38.599] [LOG]    Create new news fetcher for url: https://www.ansa.it/sito/ansait_rss.xml - Interval: 300000
        [2020-11-09 22:20:38.859] [LOG]    Create new news fetcher for url: https://www.ansa.it/sito/notizie/tecnologia/tecnologia_rss.xml - Interval: 300000
        [2020-11-09 22:20:38.863] [LOG]    Create new news fetcher for url: https://www.ansa.it/sicilia/notizie/sicilia_rss.xml - Interval: 300000
        [2020-11-09 22:20:38.866] [LOG]    Create new news fetcher for url: https://www.ansa.it/canale_scienza_tecnica/notizie/scienzaetecnica_rss.xml - Interval: 300000
        [2020-11-09 22:20:38.881] [INFO]   Checking git for module: MMM-awesome-alexa
        [2020-11-09 22:20:39.968] [INFO]   Calendar-Fetcher: Broadcasting 0 events.
        [2020-11-09 22:20:40.128] [INFO]   Newsfeed-Fetcher: Broadcasting 17 items.
        [2020-11-09 22:20:41.719] [INFO]   Newsfeed-Fetcher: Broadcasting 27 items.
        [2020-11-09 22:20:42.049] [INFO]   Newsfeed-Fetcher: Broadcasting 57 items.
        [2020-11-09 22:20:42.318] [INFO]   Newsfeed-Fetcher: Broadcasting 34 items.
        [2020-11-09 22:20:42.496] [INFO]   Calendar-Fetcher: Broadcasting 3 events.
        [2020-11-09 22:21:01.334] [LOG]    Shutting down server...
        [2020-11-09 22:21:01.337] [LOG]    Stopping module helper: updatenotification
        [2020-11-09 22:21:01.338] [LOG]    Stopping module helper: calendar
        [2020-11-09 22:21:01.340] [LOG]    Stopping module helper: MMM-awesome-alexa
        [2020-11-09 22:21:01.341] [LOG]    Stopping module helper: newsfeed
        which is the same from the logs of pm2, no error logs even there
          @LukeTheWalker ok, last debugging I can think of.
          open the developers window, ctrl-shift-i on the keyboard, select the tab labeled console and scroll up to see any errors. usually red text.
          • L Offline
            LukeTheWalker
            @sdetweil here are all the logs from the console:
            main.js:487 Initializing MagicMirror.
            translator.js:129 Loading core translation file: translations/it.json
            translator.js:154 Loading core translation fallback file: translations/en.json
            loader.js:176 Load script: modules/default/alert//alert.js
            module.js:513 Module registered: alert
            loader.js:148 Bootstrapping module: alert
            loader.js:176 Load script: modules/default/alert/notificationFx.js
            loader.js:153 Scripts loaded for: alert
            loader.js:195 Load stylesheet: modules/default/alert/notificationFx.css
            loader.js:195 Load stylesheet: vendor/css/font-awesome.css
            loader.js:155 Styles loaded for: alert
            translator.js:102 alert - Load translation fallback: translations/en.json
            /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
              protocols.This exposes users of this app to unnecessary security risks.
              Consider loading the following resources over HTTPS or FTPS.
             - http://localhost:8080/css/main.css
            - http://localhost:8080/fonts/roboto.css
            - http://localhost:8080/socket.io/socket.io.js
            - http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
            - http://localhost:8080/js/defaults.js
            - http://localhost:8080/config/config.js
            - http://localhost:8080/vendor/vendor.js
            - http://localhost:8080/modules/default/defaultmodules.js
            - http://localhost:8080/js/logger.js
            - http://localhost:8080/translations/translations.js
            - http://localhost:8080/js/translator.js
            - http://localhost:8080/js/class.js
            - http://localhost:8080/js/module.js
            - http://localhost:8080/js/loader.js
            - http://localhost:8080/js/socketclient.js
            - http://localhost:8080/js/main.js
            - http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
            - http://localhost:8080/translations/it.json
            - http://localhost:8080/translations/en.json
            - http://localhost:8080/modules/default/alert//alert.js
            - http://localhost:8080/modules/default/alert/notificationFx.js
            - http://localhost:8080/modules/default/alert/notificationFx.css
            - http://localhost:8080/vendor/css/font-awesome.css
            - http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/all.min.css
            - http://localhost:8080/vendor/node_modules/@fortawesome/fontawesome-free/css/v4-shims.min.css
            For more information and help, consult
            https://electronjs.org/docs/tutorial/security.
             This warning will not show up
            once the app is packaged.
            warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
            /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                Policy set or a policy with "unsafe-eval" enabled. This exposes users of
            (anonymous) @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145
            loader.js:157 Translations loaded for: alert
            loader.js:176 Load script: modules/default/updatenotification//updatenotification.js
            module.js:513 Module registered: updatenotification
            loader.js:148 Bootstrapping module: updatenotification
            loader.js:153 Scripts loaded for: updatenotification
            loader.js:155 Styles loaded for: updatenotification
            loader.js:157 Translations loaded for: updatenotification
            loader.js:176 Load script: modules/default/clock//clock.js
            module.js:513 Module registered: clock
            loader.js:148 Bootstrapping module: clock
            loader.js:176 Load script: vendor/node_modules/moment/min/moment-with-locales.js
            loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
            loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
            loader.js:153 Scripts loaded for: clock
            loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
            loader.js:155 Styles loaded for: clock
            loader.js:157 Translations loaded for: clock
            loader.js:176 Load script: modules/default/calendar//calendar.js
            module.js:513 Module registered: calendar
            loader.js:148 Bootstrapping module: calendar
            loader.js:236 File already loaded: moment.js
            loader.js:153 Scripts loaded for: calendar
            loader.js:195 Load stylesheet: modules/default/calendar/calendar.css
            loader.js:236 File already loaded: font-awesome.css
            loader.js:155 Styles loaded for: calendar
            loader.js:157 Translations loaded for: calendar
            loader.js:176 Load script: modules/default/compliments//compliments.js
            module.js:513 Module registered: compliments
            loader.js:148 Bootstrapping module: compliments
            loader.js:153 Scripts loaded for: compliments
            loader.js:155 Styles loaded for: compliments
            loader.js:157 Translations loaded for: compliments
            loader.js:176 Load script: modules/default/currentweather//currentweather.js
            module.js:513 Module registered: currentweather
            loader.js:148 Bootstrapping module: currentweather
            loader.js:153 Scripts loaded for: currentweather
            loader.js:195 Load stylesheet: vendor/node_modules/weathericons/css/weather-icons.css
            loader.js:195 Load stylesheet: modules/default/currentweather/currentweather.css
            loader.js:155 Styles loaded for: currentweather
            loader.js:157 Translations loaded for: currentweather
            loader.js:176 Load script: modules/MMM-awesome-alexa//MMM-awesome-alexa.js
            module.js:513 Module registered: MMM-awesome-alexa
            loader.js:148 Bootstrapping module: MMM-awesome-alexa
            loader.js:153 Scripts loaded for: MMM-awesome-alexa
            loader.js:195 Load stylesheet: modules/MMM-awesome-alexa/styles/global.css
            loader.js:155 Styles loaded for: MMM-awesome-alexa
            loader.js:157 Translations loaded for: MMM-awesome-alexa
            loader.js:176 Load script: modules/default/weatherforecast//weatherforecast.js
            module.js:513 Module registered: weatherforecast
            loader.js:148 Bootstrapping module: weatherforecast
            loader.js:153 Scripts loaded for: weatherforecast
            loader.js:236 File already loaded: weather-icons.css
            loader.js:195 Load stylesheet: modules/default/weatherforecast/weatherforecast.css
            loader.js:155 Styles loaded for: weatherforecast
            loader.js:157 Translations loaded for: weatherforecast
            loader.js:176 Load script: modules/default/newsfeed//newsfeed.js
            module.js:513 Module registered: newsfeed
            loader.js:148 Bootstrapping module: newsfeed
            loader.js:153 Scripts loaded for: newsfeed
            loader.js:155 Styles loaded for: newsfeed
            loader.js:157 Translations loaded for: newsfeed
            loader.js:195 Load stylesheet: css/custom.css
            (index):1 Refused to apply style from 'http://localhost:8080/css/custom.css' because its MIME type ('text/html') is not a supported stylesheet MIME type, and strict MIME checking is enabled.
            loader.js:206 Error on loading stylesheet: css/custom.css
            stylesheet.onerror @ loader.js:206
            alert.js:162 Starting module: alert
            updatenotification.js:19 Start updatenotification
            clock.js:46 Starting module: clock
            calendar.js:81 Starting module: calendar
            compliments.js:38 Starting module: compliments
            currentweather.js:97 Starting module: currentweather
            weatherforecast.js:87 Starting module: weatherforecast
            newsfeed.js:57 Starting module: newsfeed
            main.js:508 All modules started!
            module.js:199 currentweather is suspended.
            module.js:199 weatherforecast is suspended.
            MMM-awesome-alexa.js:1 MMM-awesome-alexa received a notification: idle - Payload: [object Object]
            api.openweathermap.org/data/2.5/forecast/daily?id=2525065&cnt=40&units=metric&lang=it&APPID=8dbb79dbda0a167be34484549a620503:1 Failed to load resource: the server responded with a status of 401 (Unauthorized)
            weatherforecast.js:261 weatherforecast: Your AppID does not support long term forecasts. Switching to fallback endpoint.
            weatherRequest.onreadystatechange @ weatherforecast.js:261
            The only place where the module is mentioned seems to be when a notification is sent to the module, which remains in idle
            Here is a screen of just the errors and warnings
            I have in fact one last idea to debug this, could you please send me your MMM-awesome-alexa folder with everything builded and working, in order to try it with my setup ?
              @LukeTheWalker I am away doing some photography. will be back this weekend, and I will try to package up something
              • L Offline
                LukeTheWalker @sdetweil
                Thank you very much, anyway I am really thankful for all the time you spent trying to debug this with me
                Really looking forward this weekend, have some nice shots!
                • L Offline
                  LukeTheWalker
                  @sdetweil may I remind you of our discussion?
                    @LukeTheWalker thanks for the nudge
                    here is a link to the zip of the working MMM-awesome-alexa folder on my pi4.
                    https://www.dropbox.com/s/2qma8jcnglbbrcg/alexa.zip?dl=0
                    • L Offline
                      LukeTheWalker
                      @sdetweil update if interested, the problem was with the Bluetooth device I was using, switched to a usb to combo jack adaptor and now it work!
                      Any idea on how to play music since amazon music is locked ?
                        @LukeTheWalker far as I know, you cannot play music thru the awesome Alexa module.
