    MMM-Covid 19 does not show
    7 Posts 6 Posters 1.9k Views 6 Watching
    • kusselinK Offline
      kusselin
      Hello, i have an api key and i have this copied in my config:
          module: "MMM-COVID19",
            updateInterval: 300000,
            worldStats: true,
            delta: true,
            lastUpdateInfo: true,
            countries: [ "Germany", "USA", "Italy", "Spain", "France" ],
            headerRowClass: "small",
      	  infoRowClass: 'small',
            rapidapiKey : "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx" // this is an example, do not try to use it for real
      but only the heading is shown "Covid-19!
      Can anybody help me please.
      here is the module:
      MMM Covid-19
      best regards
      • LordyL Offline
        Lordy
        I believe that you should write all words with “…”
        		lastUpdateInfo: "true",
        		headerRowClass: "medium",
        		infoRowClass: "big",
          sdetweil @Lordy
          @Lordy the rules
          the thing to the left of : does not need quotes
          if the thing to the right of : is a number, or true or false, then also no quotes.
          otherwise quoted. it doesn’t matter which kind as long as the start and end are the same
          • T Offline
            trix2k
            i am having the same issues. all i get is the, covid 19
            mumblebajM M 2 Replies Last reply Reply Quote 0
            • mumblebajM Offline
              mumblebaj Module Developer @trix2k
              @trix2k This is my config that works.
                          header: "COVID-19 Stats",
                          position: "middle_center",
                                   updateInterval: 86400000,
                                   worldStats: true,
                                   orderCountriesByName: true,
                                   orderAscending: true,
                                   delta: true,
                                   countries: [ "South Africa", "USA", "UK", "India", "Brazil", "France", "Spain", "Russia", "Argentina" ],
                                   infoRowClass: "small",
                                   highlightCountry: "South Africa",
                                   rapidapiKey: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx"
                Murat Esiyok @trix2k
                @trix2k
                I have the same problem… did you find a solution?
                  Murat Esiyok @kusselin
                  @kusselin
