    Trouble
    9 Posts 2 Posters 972 Views 2 Watching
      marczy236
      Does anyone can help m
      sh: 1: ./node_modules/.bin/electron: not found
      npm ERR! code ELIFECYCLE
      npm ERR! syscall spawn
      npm ERR! file sh
      npm ERR! errno ENOENT
      npm ERR! magicmirror@2.13.0 start: DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      npm ERR! spawn ENOENT
      npm ERR!
      npm ERR! Failed at the magicmirror@2.13.0 start script.
      npm WARN Local package.json exists, but node_modules missing, did you mean to install?
      npm ERR! /home/pi/.npm/_logs/2020-11-29T20_51_06_451Z-debug.log
        sdetweil @marczy236
        @marczy236 what device? Pi0?
        Use my install script, see here
          marczy236 @sdetweil
          @sdetweil it is actually a Banana Pi device with a Raspbian image
          I made it on my Ubuntu, but I want it in a Raspbian.
          I tried to run every script, bit it doesn’t work. But can you tell me, how could I do this properly?
            sdetweil @marczy236
            @marczy236 u run one script, install. Copy/paste the one line
            It assumes this is first install, so there cannot be a MagicMirror folder
              sdetweil @marczy236
              @marczy236 can u show results of uname -a
                marczy236
                pi@bpi-iot-ros-ai:~ $ uname -a
                Linux bpi-iot-ros-ai 3.4.39-BPI-M3-Kernel #1 SMP PREEMPT Sat May 26 10:03:38 UTC 2018 armv7l GNU/Linux
                  sdetweil @marczy236
                  @marczy236 little old, 2018, but should work
                    marczy236 @sdetweil
                    @sdetweil thanks a lot Master. I already made it.
                    I had some problem whit the first line of the code, but i modified it and changed the number to 8.
                    It is working now perfectly
                      sdetweil @marczy236
                      @marczy236 could u show me what u changed?
