Trouble
Does anyone can help m
sh: 1: ./node_modules/.bin/electron: not found
npm ERR! code ELIFECYCLE
npm ERR! syscall spawn
npm ERR! file sh
npm ERR! errno ENOENT
npm ERR! magicmirror@2.13.0 start:DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
npm ERR! spawn ENOENT
npm ERR!
npm ERR! Failed at the magicmirror@2.13.0 start script.
npm WARN Local package.json exists, but node_modules missing, did you mean to install?npm ERR! A complete log of this run can be found in:
npm ERR! /home/pi/.npm/_logs/2020-11-29T20_51_06_451Z-debug.log -
@marczy236 what device? Pi0?
Use my install script, see here
https://github.com/sdetweil/MagicMirror_scripts -
@sdetweil it is actually a Banana Pi device with a Raspbian image
I made it on my Ubuntu, but I want it in a Raspbian.
I tried to run every script, bit it doesn’t work. But can you tell me, how could I do this properly? -
@marczy236 u run one script, install. Copy/paste the one line
It assumes this is first install, so there cannot be a MagicMirror folder
@marczy236 can u show results of uname -a
pi@bpi-iot-ros-ai:~ $ uname -a
Linux bpi-iot-ros-ai 3.4.39-BPI-M3-Kernel #1 SMP PREEMPT Sat May 26 10:03:38 UTC 2018 armv7l GNU/Linux -
@marczy236 little old, 2018, but should work
@sdetweil thanks a lot Master. I already made it.
I had some problem whit the first line of the code, but i modified it and changed the number to 8.
It is working now perfectly -
@marczy236 could u show me what u changed?
