    Help again...
    15 Posts 2 Posters 3.4k Views 2 Watching
      smart_user
      Hello, Is it possible to show 2 different compliments at the same time on the display.
      I want one in the middle and one in the lower third.
        sdetweil @smart_user
        @smart_user yes, you could have two instances in config.js with different positions and info
          smart_user
          How do I differentiate between the two different compliment purposes in the congif.js?
          Do I use the “/n” to split them?
            @smart_user two completely different setups
            module: 'compliments',
            position: 'middle',
             config:  {
                 compliments:......
              module:'compliments',
               position:'bottom',
                config:{
                     compliments:.....
              smart_user
              @sdetweil The display is showing an “undefined” with a line
                @smart_user that is the module header, don’t know why
                add
                header: '',
                after position line on both
                  smart_user
                  @sdetweil after adding the header all I see is the line. The “undefined” is not there
                    @smart_user u did define the compliments data , right?
                    here is the default, if you remove the compliments: value completely from the config section
                    from https://docs.magicmirror.builders/modules/compliments.html#configuration-options
                    Default value:
                    	compliments: {
                    		anytime: [
                    			"Hey there sexy!"
                    		morning: [
                    			"Good morning, handsome!",
                    			"Enjoy your day!",
                    			"How was your sleep?"
                    		afternoon: [
                    			"Hello, beauty!",
                    			"You look sexy!",
                    			"Looking good today!"
                    		evening: [
                    			"Wow, you look hot!",
                    			"You look nice!",
                    			"Hi, sexy!"
                    		"....-01-01": [
                    			"Happy new year!"
                      smart_user
                      @sdetweil ummmmm I’m not sure? By that do you mean in the compliments.js?
                        @smart_user no… in config.js … NEVER edit the module source
                        			disabled:false,
                        			module: "compliments",
                        			position: "middle"
                        			disabled:false,
                        			position: "lower_third"
                          smart_user
                          My config.js file:
                          module: “compliments”,
                          position: “lower_third”
                          header: ‘’,
                          position: “middle”,
                          config:{
                          compliments: “Did you do the laundry?”
                            @smart_user the compliments thing in then module config block is an object
                             compliments: {
                            it chooses by time of day, so you need some of the time ranges… see the default in the doc
                            morning/afternoon/evening…
                            each of those is a list [] (array), even if only one entry
                            The compliments property contains an object with at least four arrays: morning, afternoon, evening and anytime
                              smart_user
                              These are what they already look like:
                              defaults: {
                              compliments: {
                              anytime: [“Make today worth it!”],
                              morning: [“Good morning!”, “Have a wonderful day”, “It’s your day today!”],
                              afternoon: [“You can do this”, “Take a small nap”, “Enjoy your meal”],
                              evening: [“Exercise time!”, “NO PAIN NO GAIN!”, “Well done for the day!”],
                              “…-01-01”: [“HAPPY NEW YEAR!”],
                              “…-12-25”: [“MERRY CHRISTMAS!”]
                                @smart_user but u edited the code.
                                the way to do this is to put that definition in config.js
                                  @smart_user the way you are supposed to do it is in config.js
                                           compliments: {
                                  header: ‘’,
                                  position: “middle”,
                                  config:{
                                        compliments: {
                                  and u leave the original code untouched. this way we can change the code, without impacting your configuration
