    Help again...
    15 Posts 2 Posters 2.7k Views 2 Watching
      smart_user
      Hello, Is it possible to show 2 different compliments at the same time on the display.
      I want one in the middle and one in the lower third.
        sdetweil @smart_user
        @smart_user yes, you could have two instances in config.js with different positions and info
          smart_user
          How do I differentiate between the two different compliment purposes in the congif.js?
          Do I use the “/n” to split them?
            @smart_user two completely different setups
            module: 'compliments',
            position: 'middle',
             config:  {
                 compliments:......
              module:'compliments',
               position:'bottom',
                config:{
                     compliments:.....
              smart_user
              @sdetweil The display is showing an “undefined” with a line
                @smart_user that is the module header, don’t know why
                add
                header: '',
                after position line on both
                  smart_user
                  @sdetweil after adding the header all I see is the line. The “undefined” is not there
                    @smart_user u did define the compliments data , right?
                    here is the default, if you remove the compliments: value completely from the config section
                    from https://docs.magicmirror.builders/modules/compliments.html#configuration-options
                    Default value:
                    	compliments: {
                    		anytime: [
                    			"Hey there sexy!"
                    		morning: [
                    			"Good morning, handsome!",
                    			"Enjoy your day!",
                    			"How was your sleep?"
                    		afternoon: [
                    			"Hello, beauty!",
                    			"You look sexy!",
                    			"Looking good today!"
                    		evening: [
                    			"Wow, you look hot!",
                    			"You look nice!",
                    			"Hi, sexy!"
                    		"....-01-01": [
                    			"Happy new year!"
                      smart_user
                      @sdetweil ummmmm I’m not sure? By that do you mean in the compliments.js?
                        @smart_user no… in config.js … NEVER edit the module source
                        			disabled:false,
                        			module: "compliments",
                        			position: "middle"
                        			disabled:false,
                        			position: "lower_third"
