    Help again...
    15 Posts 2 Posters 3.0k Views 2 Watching
      smart_user
      How do I differentiate between the two different compliment purposes in the congif.js?
      Do I use the “/n” to split them?
        sdetweil @smart_user
        @smart_user two completely different setups
        module: 'compliments',
        position: 'middle',
         config:  {
             compliments:......
          module:'compliments',
           position:'bottom',
            config:{
                 compliments:.....
          smart_user
          @sdetweil The display is showing an “undefined” with a line
            @smart_user that is the module header, don’t know why
            add
            header: '',
            after position line on both
              smart_user
              @sdetweil after adding the header all I see is the line. The “undefined” is not there
                @smart_user u did define the compliments data , right?
                here is the default, if you remove the compliments: value completely from the config section
                from https://docs.magicmirror.builders/modules/compliments.html#configuration-options
                Default value:
                	compliments: {
                		anytime: [
                			"Hey there sexy!"
                		morning: [
                			"Good morning, handsome!",
                			"Enjoy your day!",
                			"How was your sleep?"
                		afternoon: [
                			"Hello, beauty!",
                			"You look sexy!",
                			"Looking good today!"
                		evening: [
                			"Wow, you look hot!",
                			"You look nice!",
                			"Hi, sexy!"
                		"....-01-01": [
                			"Happy new year!"
                  smart_user
                  @sdetweil ummmmm I’m not sure? By that do you mean in the compliments.js?
                    @smart_user no… in config.js … NEVER edit the module source
                    			disabled:false,
                    			module: "compliments",
                    			position: "middle"
                    			disabled:false,
                    			position: "lower_third"
                      smart_user
                      My config.js file:
                      module: “compliments”,
                      position: “lower_third”
                      header: ‘’,
                      position: “middle”,
                      config:{
                      compliments: “Did you do the laundry?”
                        @smart_user the compliments thing in then module config block is an object
                         compliments: {
                        it chooses by time of day, so you need some of the time ranges… see the default in the doc
                        morning/afternoon/evening…
                        each of those is a list [] (array), even if only one entry
                        The compliments property contains an object with at least four arrays: morning, afternoon, evening and anytime
                          smart_user
                          These are what they already look like:
                          defaults: {
                          compliments: {
                          anytime: [“Make today worth it!”],
                          morning: [“Good morning!”, “Have a wonderful day”, “It’s your day today!”],
                          afternoon: [“You can do this”, “Take a small nap”, “Enjoy your meal”],
                          evening: [“Exercise time!”, “NO PAIN NO GAIN!”, “Well done for the day!”],
                          “…-01-01”: [“HAPPY NEW YEAR!”],
                          “…-12-25”: [“MERRY CHRISTMAS!”]
                            @smart_user but u edited the code.
                            the way to do this is to put that definition in config.js
                              @smart_user the way you are supposed to do it is in config.js
                                       compliments: {
                              header: ‘’,
                              position: “middle”,
                              config:{
                                    compliments: {
                              and u leave the original code untouched. this way we can change the code, without impacting your configuration
