    Help again...
    15 Posts 2 Posters 3.5k Views 2 Watching
      sdetweil @smart_user
      @smart_user that is the module header, don’t know why
      add
      header: '',
      after position line on both
        smart_user
        @sdetweil after adding the header all I see is the line. The “undefined” is not there
          @smart_user u did define the compliments data , right?
          here is the default, if you remove the compliments: value completely from the config section
          from https://docs.magicmirror.builders/modules/compliments.html#configuration-options
          Default value:
          	compliments: {
          		anytime: [
          			"Hey there sexy!"
          		morning: [
          			"Good morning, handsome!",
          			"Enjoy your day!",
          			"How was your sleep?"
          		afternoon: [
          			"Hello, beauty!",
          			"You look sexy!",
          			"Looking good today!"
          		evening: [
          			"Wow, you look hot!",
          			"You look nice!",
          			"Hi, sexy!"
          		"....-01-01": [
          			"Happy new year!"
            smart_user
            @sdetweil ummmmm I’m not sure? By that do you mean in the compliments.js?
              @smart_user no… in config.js … NEVER edit the module source
              			disabled:false,
              			module: "compliments",
              			position: "middle"
              			disabled:false,
              			position: "lower_third"
                smart_user
                My config.js file:
                module: “compliments”,
                position: “lower_third”
                header: ‘’,
                position: “middle”,
                config:{
                compliments: “Did you do the laundry?”
                  @smart_user the compliments thing in then module config block is an object
                   compliments: {
                  it chooses by time of day, so you need some of the time ranges… see the default in the doc
                  morning/afternoon/evening…
                  each of those is a list [] (array), even if only one entry
                  The compliments property contains an object with at least four arrays: morning, afternoon, evening and anytime
                    smart_user
                    These are what they already look like:
                    defaults: {
                    compliments: {
                    anytime: [“Make today worth it!”],
                    morning: [“Good morning!”, “Have a wonderful day”, “It’s your day today!”],
                    afternoon: [“You can do this”, “Take a small nap”, “Enjoy your meal”],
                    evening: [“Exercise time!”, “NO PAIN NO GAIN!”, “Well done for the day!”],
                    “…-01-01”: [“HAPPY NEW YEAR!”],
                    “…-12-25”: [“MERRY CHRISTMAS!”]
                    S 2 Replies Last reply
                      @smart_user but u edited the code.
                      the way to do this is to put that definition in config.js
                        @smart_user the way you are supposed to do it is in config.js
                                 compliments: {
                        header: ‘’,
                        position: “middle”,
                        config:{
                              compliments: {
                        and u leave the original code untouched. this way we can change the code, without impacting your configuration
