    New to this and have no idea how to implement this module, MMM-RottenTomatoes
    5 Posts 3 Posters 794 Views 3 Watching
      Datfatboi
      Hey, I’m building my first magic mirror and so far I have added a weather and commute module. I’m now trying to add a module that will show me information about upcoming movies like box office and ratings. I found the module MMM-RotenTomatoes and have downloaded the rt-scraper and GitHub CLI but I have no idea what to do after that. I have absolutely no idea what to put in that config file for it work. Can anyone help?
      https://github.com/AdamMoses-GitHub/MMM-RottenTomatoes/blob/master/MMM-RottenTomatoes.js
        sdetweil @Datfatboi
        @Datfatboi all the config is on this page
        read the two links in my signature
          Datfatboi @sdetweil
          I guess a better Question would be, in the config file is it supposed to look like this:
              			module: "MMM-RottenTomatoes",
          			showHeader: "true"
          			showBoxOffice: "true"
          			showOpeningThisWeek: "true"
          OR something like this:
          Module.register("MMM-RottenTomatoes", {
          	// setup the default config options
          	defaults: {
          		// optional
          		showHeader: true,
          		showOpeningThisWeek: true,
          		showBoxOffice: true,
          		showComingSoon: true,
          		limitOpeningThisWeek: 3,
          		limitBoxOffice: 3,
          		limitComingSoon: 3,
          		boxOfficeAfter: true,
          		mergeOpeningAndComingSoon: true,
          	// the start function
          	start: function() {
          		// log starting
          		Log.info("Starting module: " + this.name);
          		// set refresh rate to 6 hours
          		this.config.refreshRate = 6 * 60 * 60 * 1000;
                  // set an identier config tag
          		this.config.identifier = this.identifier;
          		// set loaded, error, and the update to init values
          		this.loaded = false;
          		this.errorMessage = null;
          		// set the header to this place
                  if (this.config.showHeader) {
                      this.data.header = 'Rotten Tomatoes';
          		if (this.config.limitOpeningThisWeek == 0)
          			this.config.limitOpeningThisWeek = 100;
          		if (this.config.limitBoxOffice == 0)
          			this.config.limitBoxOffice = 100;
          		if (this.config.limitComingSoon == 0)
          			this.config.limitComingSoon = 100;
                  // add this config to the helper functions
          		this.sendSocketNotification('ROTTEN_TOMATOES_REGISTER_CONFIG', this.config);
          	// the socket handler
          		// if an update was received
          		if (notification === "ROTTEN_TOMATOES_UPDATE") {
          			// check this is for this module based on the woeid
          			if (payload.identifier === this.identifier)
          				// set loaded flag, set the update, and call update dom
          				this.rtData = payload.rtData;
                          this.loaded = true;
                          this.updateDom();
                  // if sent error notice
                  if (notification === "ROTTEN_TOMATOES_TOO_MANY_ERRORS") {
                      this.errorMessage("There was an error.");
                      if (this.updateTimer !== null)
                          clearTimeout(this.updateTimer);
                      this.updateTimer = null;
                      this.updateDom();
          	cleanScore: function(theScore) {
          		if (theScore.indexOf('%') == -1)
          			return '--';
          		else
          			return theScore;
          	cleanTitle: function(theTitle) {
          		if (theTitle.length > 28)
          			return theTitle.slice(0, 28) + '...';
          		else
          			return theTitle;
          	// the get dom handler
          	getDom: function() {
                  // if an error, say so
                  if (this.errorMessage !== null) {
          			wrapper.className = "small";
          			wrapper.innerHTML = this.errorMessage;
          			return wrapper;
          		// if nothing loaded yet, put in placeholder text
          		if (!this.loaded) {
          			wrapper.innerHTML = "Awaiting Update...";
          			return wrapper;
          		var titleSize = 'xsmall';
          		var movieSize = 'xsmall';
          		var wrapper = document.createElement("table");
          		// do opening this week
          		var allOTWandCSRows = [ ];
          		if (this.config.showOpeningThisWeek) {
          			var otwData = this.rtData.openingThisWeek;
          			var otwTitleTR = document.createElement("tr");
          			otwTitleTR.className = titleSize;
          			var otwTitleTD = document.createElement("td");
          			otwTitleTD.innerHTML = "Opening This Week";
          			if (this.config.mergeOpeningAndComingSoon)
          				otwTitleTD.innerHTML = "Opening / Coming Soon";
          			otwTitleTD.colSpan = "3";
          			otwTitleTR.appendChild(otwTitleTD);
          			allOTWandCSRows.push(otwTitleTR);
          			for (var cIndex = 0;
          					(cIndex < otwData.length) && (cIndex < this.config.limitOpeningThisWeek);
          					cIndex++) {
          				var cOTW = otwData[cIndex];
          				var otwRowTR = document.createElement("tr");
          				otwRowTR.className = movieSize;
          				var otwRowMeter = document.createElement("td");
          				otwRowMeter.innerHTML = this.cleanScore(cOTW.meter) + "&nbsp;&nbsp;";
          				otwRowTR.appendChild(otwRowMeter);
          				var otwRowTitle = document.createElement("td");
          				otwRowTitle.innerHTML = this.cleanTitle(cOTW.title) + "&nbsp;&nbsp;";
          				otwRowTitle.align = 'left';
          				otwRowTR.appendChild(otwRowTitle);
          				var otwRowDate = document.createElement("td");
          				otwRowDate.innerHTML = "&nbsp;&nbsp;" + cOTW.date;
          				otwRowTR.appendChild(otwRowDate);
          				allOTWandCSRows.push(otwRowTR);
          			var csData = this.rtData.comingSoon;
          			var csTitleTR = document.createElement("tr");
          			csTitleTR.className = titleSize;
          			var csTitleTD = document.createElement("td");
          			csTitleTD.innerHTML = "Coming Soon";
          			csTitleTD.colSpan = "3";
          			csTitleTR.appendChild(csTitleTD);
          			if (!this.config.mergeOpeningAndComingSoon)
          				allOTWandCSRows.push(csTitleTR);
          					(cIndex < csData.length) && (cIndex < this.config.limitComingSoon);
          					cIndex++) {
          				var ccs = csData[cIndex];
          				var csRowTR = document.createElement("tr");
          				csRowTR.className = movieSize;
          				var csRowMeter = document.createElement("td");
          				csRowMeter.innerHTML = this.cleanScore(ccs.meter) + "&nbsp;&nbsp;";
          				csRowTR.appendChild(csRowMeter);
          				var csRowTitle = document.createElement("td");
          				csRowTitle.innerHTML = this.cleanTitle(ccs.title) + "&nbsp;&nbsp;";
          				csRowTitle.align = 'left';
          				csRowTR.appendChild(csRowTitle);
          				var csRowDate = document.createElement("td");
          				csRowDate.innerHTML = "&nbsp;&nbsp;" + ccs.date;
          				csRowTR.appendChild(csRowDate);
          				allOTWandCSRows.push(csRowTR);
          		// do box office
          		var boRows = [ ];
          		if (this.config.showBoxOffice) {
          			var boData = this.rtData.boxOffice;
          			var boTitleTR = document.createElement("tr");
          			boTitleTR.className = titleSize;
          			var boTitleTD = document.createElement("td");
          			boTitleTD.innerHTML = "Box Office";
          			boTitleTD.width = "250px";
          			boTitleTD.colSpan = "3";
          			boTitleTR.appendChild(boTitleTD);
          			boRows.push(boTitleTR);
          					(cIndex < boData.length) && (cIndex < this.config.limitBoxOffice);
          					cIndex++) {
          				var cbo = boData[cIndex];
          				var boRowTR = document.createElement("tr");
          				boRowTR.className = movieSize;
          				var boRowMeter = document.createElement("td");
          				boRowMeter.innerHTML = this.cleanScore(cbo.meter) + "&nbsp;&nbsp;";
          				boRowTR.appendChild(boRowMeter);
          				var boRowTitle = document.createElement("td");
          				boRowTitle.innerHTML = this.cleanTitle(cbo.title) + "&nbsp;&nbsp;";
          				boRowTitle.align = 'left';
          				boRowTR.appendChild(boRowTitle);
          				var boRowGross = document.createElement("td");
          				boRowGross.innerHTML = "&nbsp;&nbsp;" + cbo.gross;
          				boRowTR.appendChild(boRowGross);
          				boRows.push(boRowTR);
          		// build the table
                  var allRows = [ ];
                  // if set to show box office first, do that
          		if (!this.config.boxOfficeAfter)
          			allRows = allRows.concat(boRows);
                  // add opening this week and coming soon rows
          		allRows = allRows.concat(allOTWandCSRows);
                  // if set to show box office after, do that
          		if (this.config.boxOfficeAfter)
                  // add all rows to the return table wrapper
          		for (var cIndex = 0; cIndex < allRows.length; cIndex++) {
          			wrapper.appendChild(allRows[cIndex]);
                  // return table wrapper
          		return wrapper;
          mumblebajM S 2 Replies Last reply Reply Quote 0
          • mumblebajM Offline
            mumblebaj Module Developer @Datfatboi
            @Datfatboi You should only add the following to your config.js
            module: “MMM-RottenTomatoes”,
            position: “top_left”,
            showHeader: “true”
            showBoxOffice: “true”
            showOpeningThisWeek: “true”
              sdetweil @Datfatboi
              @Datfatboi never change the module code ( your second choice)
              unless u are fixing a bug or adding some new function.
              always put info into config.js
              now, your lines for config.js are not correct.
              		showHeader: "true"
              watch out for the quote style… the curved ones are used by MS office apps…
              we need the text ones, straight up and down
              also u are missing some required trailing commas
              look at each line, and follow the rules
              general rules for module definition
              {} and [] must be matched
              the word to the left of : does not need quotes
              the thing to the right of : if a number or, true/false does NOT need quotes
              otherwise is needs quotes, single or double doesn’t matter as long as start and end quote are the same
              if the thing on the next line is a word , then THIS line needs a trailing comma
              if the thing on the next line is {, then THIS line needs a trailing comma
              also, indentation makes it MUCH easier to see the {} and []
