    remotecompliments disappeared - please help
    47 Posts 2 Posters 19.6k Views 2 Watching
    • F
      forjer
      I’m in the process of setting up a display with MagicMirror for my Mother. I nearly had it complete and at some point my mmm-remotecompliments disappeared. No header, no border, no nothing. I’m not exactly sure when it disappeared. I was working to get some sort of remote access so I could log into it remotely, so it’s either related to that or an upgrade I did just before setting up the remote access. I’m hoping to get it installed for her Saturday and would like to get the remote compliments restored as I’ve got some helpful info in those compliments for my aging Mom.
      If you could spare some time and assist me in getting this back, I’d appreciate it.
        sdetweil @forjer
        @forjer let’s start with looking at the logs where u start mm.
        either npm start or pm2
        if pm2, then the pm2 logs --lines=???
        ??? is a number default 15
          sdetweil @forjer
          @forjer also look in the developers window, ctrl-shift-i, select the tab labeled console and scroll up to see any errors…
          F 2 Replies Last reply Reply Quote -1
          • F
            forjer @sdetweil
            @sdetweil Was I supposed to add something to get more lines? I’m pretty new to all of this.
            pi@raspberrypi:~/MagicMirror $ pm2 logs
            [TAILING] Tailing last 15 lines for [all] processes (change the value with --lines option)
            /home/pi/.pm2/pm2.log last 15 lines:
            PM2        | 2020-12-28T18:00:03: PM2 log: App [MagicMirror:0] online
            PM2        | 2020-12-28T19:14:35: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
            PM2        | 2020-12-28T19:14:35: PM2 log: Stopping app:MagicMirror id:0
            PM2        | 2020-12-28T19:14:35: PM2 log: pid=3424 msg=failed to kill - retrying in 100ms
            PM2        | 2020-12-28T19:14:35: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
            PM2        | 2020-12-28T19:14:35: PM2 log: pid=3424 msg=process killed
            PM2        | 2020-12-28T19:14:35: PM2 log: App [MagicMirror:0] starting in -fork mode-
            PM2        | 2020-12-28T19:14:35: PM2 log: App [MagicMirror:0] online
            PM2        | 2020-12-28T19:19:09: PM2 log: Change detected on path config/config.js for app MagicMirror - restarting
            PM2        | 2020-12-28T19:19:09: PM2 log: Stopping app:MagicMirror id:0
            PM2        | 2020-12-28T19:19:09: PM2 log: pid=9872 msg=failed to kill - retrying in 100ms
            PM2        | 2020-12-28T19:19:09: PM2 log: App [MagicMirror:0] exited with code [0] via signal [SIGINT]
            PM2        | 2020-12-28T19:19:09: PM2 log: pid=9872 msg=process killed
            PM2        | 2020-12-28T19:19:09: PM2 log: App [MagicMirror:0] starting in -fork mode-
            PM2        | 2020-12-28T19:19:09: PM2 log: App [MagicMirror:0] online
            /home/pi/.pm2/logs/MagicMirror-error.log last 15 lines:
            0|MagicMir |
            0|MagicMir | npm ERR! A complete log of this run can be found in:
            0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-12-28T20_32_36_217Z-debug.log
            0|MagicMir |
            0|MagicMir | (electron:1239): Gtk-WARNING **: 14:32:38.725: cannot open display: :0
            0|MagicMir | npm ERR! code ELIFECYCLE
            0|MagicMir | npm ERR! errno 1
            0|MagicMir | npm ERR! magicmirror@2.13.0 start: `DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js`
            0|MagicMir | npm ERR! Exit status 1
            0|MagicMir | npm ERR! Failed at the magicmirror@2.13.0 start script.
            0|MagicMir | npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
            0|MagicMir |
            0|MagicMir | npm ERR!     /home/pi/.npm/_logs/2020-12-28T20_32_38_794Z-debug.log
            /home/pi/.pm2/logs/MagicMirror-out.log last 15 lines:
            0|MagicMir | > DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
            0|MagicMir |
            0|MagicMir | [2020-12-28 19:19:14.178] [LOG]    Starting MagicMirror: v2.13.0
            0|MagicMir | [2020-12-28 19:19:14.191] [LOG]    Loading config ...
            0|MagicMir | [2020-12-28 19:19:14.205] [LOG]    Loading module helpers ...
            0|MagicMir | [2020-12-28 19:19:14.209] [LOG]    No helper found for module: clock.
            0|MagicMir | [2020-12-28 19:19:18.830] [LOG]    Initializing new module helper ...
            0|MagicMir | [2020-12-28 19:19:18.832] [LOG]    Module helper loaded: MMM-RemoteCompliments
            0|MagicMir | [2020-12-28 19:19:18.833] [LOG]    All module helpers loaded.
            0|MagicMir | [2020-12-28 19:19:19.135] [LOG]    Starting server on port 8080 ...
            0|MagicMir | [2020-12-28 19:19:19.160] [LOG]    Server started ...
            0|MagicMir | [2020-12-28 19:19:19.162] [LOG]    Connecting socket for: MMM-RemoteCompliments
            0|MagicMir | [2020-12-28 19:19:19.171] [LOG]    Starting node helper for: MMM-RemoteCompliments
            0|MagicMir | [2020-12-28 19:19:19.172] [LOG]    Sockets connected & modules started ...
            0|MagicMir | [2020-12-28 19:19:19.313] [LOG]    Launching application.
            • F
              forjer @sdetweil
              @sdetweil In the developers window, it looks like I’ve got 3 errors, 1 warning and 1 issue. I’m not sure the right way to capture and post them.
                sdetweil @forjer
                @forjer copy paste.
                can’t open display :0
                are u doing this over ssh, vnc,??
                • F
                  forjer @sdetweil
                  @sdetweil said in remotecompliments disappeared - please help:
                  oing this over ssh,
                  I’m logged in directly. And thanks for giving it a look.
                  Developers window
                  cdn.carbonads.com/carbon.js?serve=CK7IC23N&placement=magicmirrorbuilders:1 Failed to load resource: net::ERR_BLOCKED_BY_CLIENT
                  translator.js:7 Missing key in translation token "global:"
                  n @ translator.js:7
                  3favicon.ico:1 Failed to load resource: the server responded with a status of 404 ()
                  DevTools failed to load SourceMap: Could not load content for https://forum.magicmirror.builders/assets/src/modules/pulling-drawer.js.map: HTTP error: status code 404, net::ERR_HTTP_RESPONSE_CODE_FAILURE
                    sdetweil @forjer
                    @forjer i think u are looking at the magicmirror.builders web site window not the mm window
                    what pi is this?
                    F 2 Replies Last reply Reply Quote 0
                    • F
                      forjer @sdetweil
                      @sdetweil As I said…I’m pretty new at this. Lol.
                      I’ve commented out all modules except the clock and MMM-RemoteCompliments.
                      main.js:487 Initializing MagicMirror.
                      translator.js:129 Loading core translation file: translations/en.json
                      translator.js:154 Loading core translation fallback file: translations/en.json
                      loader.js:176 Load script: modules/default/clock//clock.js
                      module.js:513 Module registered: clock
                      loader.js:148 Bootstrapping module: clock
                      loader.js:176 Load script: vendor/node_modules/moment/min/moment-with-locales.js
                      loader.js:176 Load script: vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                      loader.js:176 Load script: vendor/node_modules/suncalc/suncalc.js
                      loader.js:153 Scripts loaded for: clock
                      loader.js:195 Load stylesheet: modules/default/clock/clock_styles.css
                      loader.js:155 Styles loaded for: clock
                      loader.js:157 Translations loaded for: clock
                      loader.js:176 Load script: modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js
                      module.js:513 Module registered: MMM-RemoteCompliments
                      loader.js:148 Bootstrapping module: MMM-RemoteCompliments
                      loader.js:176 Load script: modules/MMM-RemoteCompliments//scripts/jquery-3.3.1.min.js
                      loader.js:153 Scripts loaded for: MMM-RemoteCompliments
                      loader.js:155 Styles loaded for: MMM-RemoteCompliments
                      loader.js:157 Translations loaded for: MMM-RemoteCompliments
                      loader.js:195 Load stylesheet: css/custom.css
                      :8080/modules/default/clock//clock.js:46 Starting module: clock
                      main.js:508 All modules started!
                      /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95 Electron Security Warning (Insecure Resources) This renderer process loads resources using insecure
                        protocols.This exposes users of this app to unnecessary security risks.
                        Consider loading the following resources over HTTPS or FTPS.
                       - http://localhost:8080/css/main.css
                      - http://localhost:8080/fonts/roboto.css
                      - http://localhost:8080/socket.io/socket.io.js
                      - http://localhost:8080/vendor/node_modules/nunjucks/browser/nunjucks.min.js
                      - http://localhost:8080/js/defaults.js
                      - http://localhost:8080/config/config.js
                      - http://localhost:8080/vendor/vendor.js
                      - http://localhost:8080/modules/default/defaultmodules.js
                      - http://localhost:8080/js/logger.js
                      - http://localhost:8080/translations/translations.js
                      - http://localhost:8080/js/translator.js
                      - http://localhost:8080/js/class.js
                      - http://localhost:8080/js/module.js
                      - http://localhost:8080/js/loader.js
                      - http://localhost:8080/js/socketclient.js
                      - http://localhost:8080/js/main.js
                      - http://localhost:8080/fonts/node_modules/roboto-fontface/fonts/roboto-condensed/Roboto-Condensed-Regular.woff2
                      - http://localhost:8080/translations/en.json
                      - http://localhost:8080/modules/default/clock//clock.js
                      - http://localhost:8080/vendor/node_modules/moment/min/moment-with-locales.js
                      - http://localhost:8080/vendor/node_modules/moment-timezone/builds/moment-timezone-with-data.js
                      - http://localhost:8080/vendor/node_modules/suncalc/suncalc.js
                      - http://localhost:8080/modules/default/clock/clock_styles.css
                      - http://localhost:8080/modules/MMM-RemoteCompliments//MMM-RemoteCompliments.js
                      - http://localhost:8080/modules/MMM-RemoteCompliments//scripts/jquery-3.3.1.min.js
                      - http://localhost:8080/css/custom.css
                      For more information and help, consult
                      https://electronjs.org/docs/tutorial/security.
                       This warning will not show up
                      once the app is packaged.
                      warnAboutInsecureResources @ /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:95
                      /home/pi/MagicMirror/node_modules/electron/dist/resources/electron.asar/renderer/security-warnings.js:145 Electron Security Warning (Insecure Content-Security-Policy) This renderer process has either no Content Security
                          Policy set or a policy with "unsafe-eval" enabled. This exposes users of
                      • F
                        forjer @sdetweil
                        @sdetweil And it’s a 3 B+
                          sdetweil @forjer
                          @forjer show me the config for those modules…
                          do u have a position set for compliments
                          • F
                            forjer @sdetweil
                            @sdetweil I originally had a position of “upper_third” set but removed that yesterday when I started manually debugging. I just added it back in now as shown below with no change to the behavior…still no remote compliments showing.
                            Here’s my clock…
                            			module: "clock",
                            			position: "top_center"
                            This is how my remote compliments looked yesterday before I started manually debugging…
                            			module: "MMM-RemoteCompliments",
                            			header: "",
                            			position: "upper_third",
                            				header: "MMM-RemoteCompliments",
                            				fetchInterval: 4000,
                            This is what I had at the time I ran the above developers window and pm2 log…
                            			    // See below for configurable options
                            And I just threw the position back in with no change to the behavior…no remotecompliments showing whatsoever…
                            module: “MMM-RemoteCompliments”,
                            position: “upper_third”,
                            header: “MMM-RemoteCompliments”,
                              sdetweil @forjer
                              @forjer u do have a url or something in the config section, yes? u have no content like that
                              • F
                                forjer @sdetweil
                                @sdetweil The only url I have is for the default calendar module which I currently have commented out. The RemoteCompliments is the module that runs through Google Drive. As far as I know RemoteCompliments doesn’t require an url.
                                  sdetweil @forjer
                                  @forjer ok, I see the user setup in the drives folder
                                  let’s look in the console again, pm2 logs
                                  the Google authentication expires after a day.
                                  • F
                                    forjer @sdetweil
                                    @sdetweil For the pm2 logs, do I just do the default last 15 lines or should I do more. And if I do more I suppose there’s some"sensitive" stuff I should wipe out?
                                    And as far a sGoogle authentication expiring, please expand on that. I set this up some weeks ago and hadn’t had a problem until sometime in the last few days…I’m thinking yesterday.
                                      sdetweil @forjer
                                      @forjer if the system isn’t run for a while a day I think… just helped another user with authentication failure
                                      can’t think of any personal info in the log w those two modules…
                                      if concerned, pm2 stop 0,
                                      pm2 flush
                                      pm2 start 0
                                      pm2 logs
                                      • F
                                        forjer @sdetweil
                                        pi@raspberrypi:~ $ pm2 logs
                                        PM2        | 2020-12-28T20:37:03: PM2 log: App [MagicMirror:0] starting in -fork mode-
                                        PM2        | 2020-12-28T20:37:03: PM2 log: App [MagicMirror:0] online
                                        0|MagicMir |
                                        0|MagicMir | [2020-12-28 20:37:07.031] [LOG]    Starting MagicMirror: v2.13.0
                                        0|MagicMir | [2020-12-28 20:37:07.045] [LOG]    Loading config ...
                                        0|MagicMir | [2020-12-28 20:37:07.060] [LOG]    Loading module helpers ...
                                        0|MagicMir | [2020-12-28 20:37:07.064] [LOG]    No helper found for module: clock.
                                        0|MagicMir | [2020-12-28 20:37:10.491] [LOG]    Initializing new module helper ...
                                        0|MagicMir | [2020-12-28 20:37:10.492] [LOG]    Module helper loaded: MMM-RemoteCompliments
                                        0|MagicMir | [2020-12-28 20:37:10.493] [LOG]    All module helpers loaded.
                                        0|MagicMir | [2020-12-28 20:37:10.714] [LOG]    Starting server on port 8080 ...
                                        0|MagicMir | [2020-12-28 20:37:10.739] [LOG]    Server started ...
                                        0|MagicMir | [2020-12-28 20:37:10.740] [LOG]    Connecting socket for: MMM-RemoteCompliments
                                        0|MagicMir | [2020-12-28 20:37:10.744] [LOG]    Starting node helper for: MMM-RemoteCompliments
                                        0|MagicMir | [2020-12-28 20:37:10.745] [LOG]    Sockets connected & modules started ...
                                        0|MagicMir | [2020-12-28 20:37:10.891] [LOG]    Launching application.
                                          sdetweil @forjer
                                          @forjer no logging. sheesh
                                          edit the module node_helper.js file,
                                          take the //
                                          off line 65 and 66
                                            @forjer I think u will have to delete the Token.json file and rerun drives/setup.js
                                            • 1 / 3
