    Blank Screen after reboot
    4 Posts 3 Posters 886 Views 3 Watching
      anishfer
      magicmirror@2.13.0 start /home/pi/MagicMirror
      DISPLAY=“${DISPLAY:=:0}” ./node_modules/.bin/electron js/electron.js
      [2021-01-01 21:22:56.446] [LOG] Starting MagicMirror: v2.13.0
      [2021-01-01 21:22:56.454] [LOG] Loading config …
      [2021-01-01 21:22:56.458] [ERROR] WARNING! Could not validate config file. Starting with default configuration. Please correct syntax errors at or above this line: /home/pi/MagicMirror/config/config.js:76
      roundTemp: true,
      SyntaxError: Unexpected identifier
      at Module._compile (internal/modules/cjs/loader.js:722:23)
      at Object.Module._extensions…js (internal/modules/cjs/loader.js:798:10)
      at Module.load (internal/modules/cjs/loader.js:645:32)
      at Function.Module._load (internal/modules/cjs/loader.js:560:12)
      at Module.require (internal/modules/cjs/loader.js:685:19)
      at require (internal/modules/cjs/helpers.js:16:16)
      at loadConfig (/home/pi/MagicMirror/js/app.js:70:12)
      at App.start (/home/pi/MagicMirror/js/app.js:217:3)
      at Object. (/home/pi/MagicMirror/js/electron.js:129:7)
      at Module._compile (internal/modules/cjs/loader.js:786:30)
      [2021-01-01 21:22:56.459] [LOG] Loading module helpers …
      [2021-01-01 21:22:56.504] [LOG] Initializing new module helper …
      [2021-01-01 21:22:56.505] [LOG] Module helper loaded: updatenotification
      [2021-01-01 21:22:56.506] [LOG] No helper found for module: helloworld.
      [2021-01-01 21:22:56.507] [LOG] All module helpers loaded.
      [2021-01-01 21:22:56.639] [LOG] Starting server on port 8080 …
      [2021-01-01 21:22:56.653] [LOG] Server started …
      [2021-01-01 21:22:56.654] [LOG] Connecting socket for: updatenotification
      [2021-01-01 21:22:56.655] [LOG] Sockets connected & modules started …
      [2021-01-01 21:22:56.763] [ERROR] Whoops! There was an uncaught exception…
      [2021-01-01 21:22:56.764] [ERROR] Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
      at Server.setupListenHandle [as _listen2] (net.js:1226:14)
      at listenInCluster (net.js:1274:12)
      at GetAddrInfoReqWrap.doListen [as callback] (net.js:1413:7)
      at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:65:10) {
      code: ‘EADDRINUSE’,
      errno: ‘EADDRINUSE’,
      syscall: ‘listen’,
      address: ‘127.0.0.1’,
      port: 8080
      [2021-01-01 21:22:56.771] [ERROR] MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
      [2021-01-01 21:22:56.772] [ERROR] If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
      [2021-01-01 21:22:56.775] [LOG] Launching application.
      A S 2 Replies Last reply Reply Quote 0
        ashishtank Module Developer @anishfer
        @anishfer said in Blank Screen after reboot:
        here is the clue Error: listen EADDRINUSE: address already in use 127.0.0.1:8080
        some other process or another instance of MM is using the 8080 port. so either you need to stop that application or need to use another port.
        You can use another port in config.js file by changing it to some other value.
        port: 8080,
        also looks like there are issues with config.js correct them as well.
        roundTemp: true,
          sdetweil @anishfer
          @anishfer
          at
          usually means a missing trailing comma on the previous line
            anishfer @ashishtank
            @ashishtank thanks
