    Show IP camera in Magic Mirror
    17 Posts 7 Posters 14.9k Views 8 Watching
    • D
      drx1984
      Hello everybody,
      can someone help me to display my “Reolink” IP camera on the MagicMirror?
      Have already tried a couple of modules but without success.
      • MMM-iFrame
      • MMM-RTSPStream
      What worked with the module “MMM-iFarme”, if I insert the “rtsp-stream” link from Reolink in the config, and then start MagicMirror, MagicMirror and the VLC player start separately with the stream.
      Could someone show me an example config?
      • BKeyportB
        BKeyport Module Developer
        RTSPStream is broken and won’t be supported anymore. Do you know if the camera is using h.264?
        If so, you could use OMXPlayer directly, bypassing MM, like I do. If it’s H.265, It can be handled by VLC or FFMPeg, but I don’t know how that would work.
        • D
          drx1984 @BKeyport
          @BKeyport yes it is a h.264, it is a Reolink IP camera RLC-410-5MP.
          I cannot install an OMXPlayer on RaspianOS because the system runs on a Proxmox server.
          Is there another way to just show a screenshot of the IP camera?
          • Cr4z33C
            Cr4z33 @drx1984
            @drx1984 try with MMM-FreeboxTV?
            • D
              drx1984 @Cr4z33
              @Cr4z33 said in Show IP camera in Magic Mirror:
              MMM-FreeboxTV
              you mean the module MMM-FreeBox-Monitor?
              Doesn’t work either.
              • BKeyportB
                BKeyport Module Developer @drx1984
                @drx1984 Ahh! I originally had one of those in use. Using OMXPlayer directly is likely the best option.
                What I’ve done is block out a section of my screen using a custom module that’s not published, then, using a bash script, I launch OMX Player with a command line like:
                omxplayer --avdict rtsp_transport:tcp --live --orientation [rotation] --win "[X1 Y1 X2 Y2]" rtsp://[URL]
                “Rotation” is the rotation of your monitor, 0 (Normal), 90 (right portrait), 180 (upside down), 270 (left portrait)
                “X1” is the left X position NOT CONSIDERING ROTATION.
                “X2” is the right X position NOT CONSIDERING ROTATION.
                “Y1” is the top Y position NOT CONSIDERING ROTATION.
                “Y2” is the bottom Y position NOT CONSIDERING ROTATION.
                omxplayer will then launch on top of the mirror screen.
                Example:
                omxplayer --avdict rtsp_transport:tcp --live --orientation 90 --win "1500 325 1915 1075" rtsp://U:P@A/2/h265/major
                My screen is rotated right portrait, so I rotate OMX to match. (90)
                The window I need cut out is 700x415 pixels, my resolution is 1080x1920. You’ll notice I have it 5px off the edge to assure I see everything, and I’ve got it in the upper right corner of my display. my camera I use now instead of the Reolink is using that URL, even though it puts out a H264 stream at the moment (I’m looking for an option to go to H265 as h264 uses flash for display)
                • J
                  jasondreher
                  I am using iFrame. But also using BlueIris to stream the IP camera to a http site, makes things much easier, plus I can get motion from BlueIris.
                  		module: 'MMM-iFrame',
                  		position: 'bottom_left',	// This can be any of the regions.
                  				url: ["http://192.XXX.X.XXX:XXXX/mjpg/CAM1/video.mjpg"],
                  				updateInterval: 0.5 * 60 * 1000, // rotate URLs every 30 seconds
                  				width: "1200px", // Optional. Default: 100%
                  				height: "600px" //Optional. Default: 100px
                  • BKeyportB
                    I now have MMM-FreeboxTV working displaying my IP Camera.
                    Here’s the trick:
                    Edit streamsConfig.json and strip out everything but channel 2.
                    Channel 2 should be:
                    "2": "rtsp://[url]"
                    Then: in config.js
                    	module: 'MMM-FreeboxTV',
                    	position: 'top_right',
                    		debug: false,
                    		autoReplay: true,
                    		fullscreen: false,
                    		width: [to taste],
                    		height: [to taste],
                    		onStart: 2,
                    		onStartDelay: 5000,
                    		streams: "streamsConfig.json"
                    PS: Because of my module size, I needed to still use my unlisted block module. :(
                    D M 2 Replies Last reply Reply Quote 0
                    • D
                      drx1984 @BKeyport
                      @BKeyport do you mean that
                      Unfortunately I don’t see a stream either
                      • D
                        drx1984 @jasondreher
                        @jasondreher Unfortunately, iframe does not work with Reolink cameras.
                        • BKeyportB
                          @drx1984 you didn’t follow my directions. The system expects the channels in the json file.
                          • D
                            drx1984 @BKeyport
                            @BKeyport Good morning thanks,
                            Everything works fine locally now.
                            But when I call up my MagicMirror via a browser on another computer via an IP address, there is no cam stream.
                            I think it only works locally?
                            Is there any other solution? Or at least display a picture from the IP camera?
                            • BKeyportB
                              Sadly, no. Other programs had a option for a remote feed, like using OMXPlayer locally, and mmfpeg remotely, but those are abandoned.
                              • G
                                goprojojo @drx1984
                                @drx1984 That’s too bad. Hope there is a solution for Reolink. Any confirmed camera brand that does work with MMM-FreeboxTV?
                                • BKeyportB
                                  BKeyport Module Developer @goprojojo
                                  @goprojojo If it works with VLC, it’ll work with Freebox. go to https://www.ispyconnect.com/man.aspx?n=Reolink to get the URL you’ll need, and try it on VLC.
                                  • M
                                    meaple @BKeyport
                                    @bkeyport Got my streamsConfig.json set (also tried without [])17d988e5-4ac0-436b-b33e-3ce815f9b19c-image.png and free box set in config.js bf138c16-30b5-4411-8fbe-319ea0423ce4-image.png
                                    Any idea?
                                    • H
                                      hrmax23
                                      Anyone happen to know where I can find MMM-FreeboxTV?
