    MMM-FRITZ-Box-Callmonitor
    11 Posts 7 Posters 2.7k Views 6 Watching
    • C Offline
      chris47803
      Hi there,
      I’m sorry for my bad english.
      I had it translated with google.
      I would like to run the call monitor in my mirror.
      An incoming call is also indicated.
      Unfortunately not missed calls.
      Even if I enter the wrong password, nothing changes on the display.
      I hope you can help me.
      Kind regards
      config.js
      		module: "MMM-FRITZ-Box-Callmonitor",
      		position: "bottom_left",	// This can be any of the regions. Best results in left or right regions.
      		header: "Letzte Anrufe", // This is optional
      			showContactsStatus: "true",
      			fritzIP: "192.168.2.2",
      			maximumCallDistance: "60",
                              maximumCalls: "5",
                              reloadContactsInterval: "1",
      		        username: "pi",
                              password: "*****",
                              //vCard: "/home/pi/MagicMirror/modules/MMM-FRITZ-Box-Callmonitor/vCard Export.vcf",
      			debug: "true",
      MMM-FRITZ-Box-Callmonitor.js
      Module.register("MMM-FRITZ-Box-Callmonitor", {
      	requiresVersion: "2.0.0",
      	// Default module config.
      	defaults: {
      		numberFontSize: 30,
      		vCard: false,
      		fritzPort: 1012,
      		minimumCallLength: 0,
      		maximumCallDistance: 60,
      		maximumCalls: 5,
      		fade: false,
      		debug: false,
      		fadePoint: 0.25,
      		username: "pi",
      		password: "*****",
      		reloadContactsInterval: 1, // 30 minutes, set to 0 to disable
      		deviceFilter: [], // [] means no filtering
      		showContactsStatus: true
      • C Offline
        chris47803
        Now it’s working.
        I uninstalled Python and installed version 0.5.0.
        best regards, Chris
          ShadowMG Project Sponsor @chris47803
          @chris47803 said in MMM-FRITZ-Box-Callmonitor:
          Any hint on where you got this from and how you installed it?
          Thx!
            Murph @chris47803
            @chris47803 How did you do?
            • C Offline
              coernel
              I have the same problem. What do you mean by “I uninstalled Python?” So if I uninstall Python many other things won’t work.
              S ? 2 Replies Last reply Reply Quote 0
                sdetweil @coernel
                @coernel he installed a prior version of python
                I added words to complete his sentence
                I uninstalled the current version of Python and installed python version 0.5.0
                • C Offline
                  coernel @sdetweil
                  @sdetweil Hey thanks, that is exactly what I understood. And that arises the question: With an older version of python isn’t there the danger of other modules being broken? So would there be the possibility to force an older python version for the specific module only?
                    sdetweil @coernel
                    @coernel sorry, no idea how to run specific versions of python with specific modules
                    • ? Offline
                      A Former User @coernel
                      Dear all,
                      has anyone here come up with a more, shall I say, “sustainable” solution? According to Chris, he has installed version 0.5.0 of Python , I have versions 2.7 and 3.9 on my Raspi, version 0.5.0 seems very old and dangerous in conjunction with other modules. In addition, Python no longer lists this version under the ancient versions and does not offer it for download. So now I have no way of getting the module to work. I would be grateful for any help, including instructions on how to install version 0.5.0.
                      Thanks and regards,
                      Docci
                      U 1 Reply Last reply Reply Quote 2
                      • U Offline
                        uschmitt @Guest
                        @Docjump said in MMM-FRITZ-Box-Callmonitor:
                        There is another fork of this module
                        MMM-FRITZ-Box-Callmonitor-py3
                        There is a comment:
                        The Code is updated to work with python 3 and the latest MagicMirror Version ( Updates of this Module last year ), so much younger than the module you are using.
                        I installed this version 2 Month ago on Bullseye and Bookworm Debian 11/12.
                        And when I remember correct I had had only problems with installing the addon fritzconnection on Bookworm. Bullseye was fine.
                        Issue was “sudo pip install fritzconnection”.
                        I have to look what I did there exactly. One Solution was simple to copy the python modules manually to a directory, the other was to make a “virtual” python installation with “python3 -m venv xyz”.
                        If interests are there I can try to reinstall and note some instructions.
                        Regards
                        Uwe
                        ? 1 Reply Last reply Reply Quote 1
