    MMM-CalendarExt2 not showing up
    3 Posts 3 Posters 874 Views 3 Watching
    • C Offline
      codac
      I have already searched the other posts regarding this topic, but no solution worked for me. The calendar is a Nextcloud calendar, hence the ?export part.
      The module is simply not showing up and I can’t find the error.
      The config is:
                              module: "MMM-CalendarExt2",
                                                              url: "https://<usernam>:<password>@<hostname>/remote.php/dav/calendars/<username>/privatecalendar?export",
                                      views: [
                                                      mode: "daily",
                                                      locale: "de-DE",
                                                      calendars: ["PrivateCalendar"],
                                      scenes: [
                                                      views: [],
      • BKeyportB Offline
        BKeyport Module Developer @codac
        @codac Let’s eliminate the obvious.
        Change your URL to this:
        https://calendar.google.com/calendar/ical/brendan.keyport%40gmail.com/public/basic.ics
        It should result in a daily event “test” for a half hour.
        If it does not work, reboot your pi and try again.
        If it does, please check your calendar app for a specific “ICS” export. Some sites use both a web export, and a ICS export. the web export is good for google and outlook, but not us.
          johnny1234boy
          I am also new to MM, but here are the fields that are missing on yours compared to mine. I am not sure which is required and which is optional.
          				rotateInterval: 1000*60,
          							className: "privatecalendar",
                                          views: [
          						mode: "daily",
                                                          locale: "de-DE",
          						slotCount: 4,
                                          scenes: [
                                                          views:["VIEW1"],
