    MMM-RandomBibleVerse
    1 Posts 1 Posters 481 Views 1 Watching
      Momentumv 0
      https://github.com/MomentumV/MMM-RandomBibleVerse
      This module, largely based off of MMM-DailyBibleVerse, gives you the option of having more than one verse a day! as of the latest version,
      It is pretty limited to only ESV, NIV, KJV, NKJV versions, though. This is due to changing the verse provider from BibleGateway to dailyverses.net.
      You can set the refresh interval in the config from a minimum of 0.2 minutes (12 seconds) to… ? I didn’t set a maximum! You could have a verse of the MONTH! ( that’s 602430 = 43,200 minutes). The default value is 60 minutes.
      screenshot
      The actual function part of the code uses the cheerio package to parse html from dailyverses.net, and pull the verse parts out using CSS selectors.
