    New to MM - Duplicate screens/overlapping help!!
    12 Posts 3 Posters 3.0k Views 3 Watching
      Bushby32
      Hi all,
      So I decided to give MM a go. I removed the LCD display (1920x1080) out of an old laptop, purchased the controller board and my raspberry pi 4 is up and running great.
      I installed the MM following the guide on the website. When I start MM, I get this kind of display:
      If I hit F11 and reduce the full screen to a window, I can resize the window and creat a small MM.
      As soon as I start increasing the size of the MM, it seems to duplicate!! I have tried Ctrl - and + to zoom in and out, Ctrl 0 to reset the zoom, added different zoom: 0.5, 1.5, values etc on config.je.
      I am sure it is something quite simple, but the pi is fairly new to me. I hope someone can point me in the right direction! I want just a single display of MM at the correct size.
      • W Offline
        Wenike @Bushby32
        @bushby32 Just checking but your Pi is set to the proper resolution and size on the desktop outside of MM, correct?
          Bushby32 @Wenike
          @wenike Hi Wenike, thanks for the reply! Yes, checked on screen preferences and set to correct resolution, 1920x1080, and as you can see on screenshot 2 and 3, it fills the display as it should on the raspberry pi system. Is there somewhere in the code I need you change to match this? Every guide I have looked at and followed seems to have no problem with the first start up!
          I have tried resetting the pi and reinstalling MM with no luck.
            sdetweil @Bushby32
            @bushby32 u can try to use the electronOptions
            address:"?????",
            electronOptions:{x:0, y:0, width:1920, height:1080, fullScreen:false, kiosk:false},
            see https://www.electronjs.org/docs/api/browser-window
            also mm code js/electron.js line 23
              Bushby32 @sdetweil
              @sdetweil Hi, thanks for the reply. I have changed the electron options, see screenshot below.
              Still no luck! have I done something wrong?
                Bushby32
                @sdetweil And I have tried placing that code here:
                  sdetweil @Bushby32
                  @bushby32 in the right place, can add after
                  zoom:0
                  B 2 Replies Last reply Reply Quote 0
                    Bushby32 @sdetweil
                    @sdetweil Hi Sam,
                    I placed it after zoom and changed zoom:0
                    Still no luck! now just a black screen, if i reduce the window it comes up like this:
                    So strange!! :(
                      Bushby32 @sdetweil
                      Feels like it is getting worse haha
                        sdetweil @Bushby32
                        @bushby32 weird. stop mm
                        look in the users home folder
                        erase
                        .config/electron
                        restart mm
                          Bushby32 @sdetweil
                          @sdetweil Hi, Sorry what users home folder?
                          I’m not sure .config/electron you are referring to!
                            sdetweil @Bushby32
                            @bushby32 users home not magicmirror
                            ~/.config
                            u wont see folders that start w dot from the file manager
