    New to MM - Duplicate screens/overlapping help!!
    12 Posts 3 Posters 2.9k Views 3 Watching
      Bushby32 @Wenike
      @wenike Hi Wenike, thanks for the reply! Yes, checked on screen preferences and set to correct resolution, 1920x1080, and as you can see on screenshot 2 and 3, it fills the display as it should on the raspberry pi system. Is there somewhere in the code I need you change to match this? Every guide I have looked at and followed seems to have no problem with the first start up!
      I have tried resetting the pi and reinstalling MM with no luck.
        sdetweil @Bushby32
        @bushby32 u can try to use the electronOptions
        address:"?????",
        electronOptions:{x:0, y:0, width:1920, height:1080, fullScreen:false, kiosk:false},
        see https://www.electronjs.org/docs/api/browser-window
        also mm code js/electron.js line 23
          Bushby32 @sdetweil
          @sdetweil Hi, thanks for the reply. I have changed the electron options, see screenshot below.
          Still no luck! have I done something wrong?
            Bushby32
            @sdetweil And I have tried placing that code here:
              sdetweil @Bushby32
              @bushby32 in the right place, can add after
              zoom:0
                Bushby32 @sdetweil
                @sdetweil Hi Sam,
                I placed it after zoom and changed zoom:0
                Still no luck! now just a black screen, if i reduce the window it comes up like this:
                So strange!! :(
                  Bushby32 @sdetweil
                  Feels like it is getting worse haha
                    sdetweil @Bushby32
                    @bushby32 weird. stop mm
                    look in the users home folder
                    erase
                    .config/electron
                    restart mm
                      Bushby32 @sdetweil
                      @sdetweil Hi, Sorry what users home folder?
                      I’m not sure .config/electron you are referring to!
                        sdetweil @Bushby32
                        @bushby32 users home not magicmirror
                        ~/.config
                        u wont see folders that start w dot from the file manager
