    PIR Sensor won't wake up
    22 Posts 7 Posters 10.6k Views 7 Watching
      Sceetch
      @jste84
      i guess i have the same issue.
      you can try easily with this module
      https://github.com/bugsounet/MMM-NewPIR
      you can change inside the module the mode
      mode: 1 - use vgencmd
      mode: 3 - use tvservice
      in my case it works. But i think i have an adjustment problem.
      The screen turns off and also the sensor can wake up the screen again.
      But if there is no movement, the screen turn on randomly. Currently i have no solution. I guess there is some wrong settings on sensors Potentiometer.
      ebolisaE 1 Reply Last reply Reply Quote 0
      • ebolisaE Offline
        ebolisa @Sceetch
        @sceetch I came to a conclusion to not use any modules which do not show any info on the screen. So, in this case, I use a python script at boot which monitors a PIR and executes an HDMI on/off cmd ;)
