    MMM-GoogleAssistant : Jarvis don't listen my calls !
    3 Posts 2 Posters 1.3k Views 2 Watching
    • Tom_LabHIdouilleT
      Tom_LabHIdouille
      Hi everyone,
      I’m novice on Magic Mirror, but i’m definitively in love with this project. I have some issues trying to install MMM-GoogleAssistant on my mirror.
      All of the installation run well, until I launch the MM application. I try to call Jarvis, but I don’t receive any answer.
      When I check my devices, audio and microphone are running well.
      Here is a copy of my config :
        module: "MMM-GoogleAssistant",
        //position: "fullscreen_above",
        position: "middle_center",
          debug: false,
          assistantConfig: {
            lang: "fr-FR",
            projectId: "", // Required to use gaction.
            modelId: "", // (OPTIONAL for gaction)
            instanceId: "", // (OPTIONAL for gaction)
            latitude: 51.508530,
            longitude: -0.076132,
          responseConfig: {
            useScreenOutput: true,
            screenOutputCSS: "screen_output.css",
            screenOutputTimer: 5000,
            screenRotate: true,
            activateDelay: 250,
            useAudioOutput: true,
            useChime: true,
            newChime: false,
            useNative: false,
            playProgram: "mpg321"
          micConfig: { // put there configuration generated by auto-installer
            recorder: "arecord",
            device: "plughw:2",
      	//device: "hw:<2>,<0>",
          snowboy: {
            useSnowboy: true,
            usePMDL: false,
            audioGain: 2.0,
            Frontend: true,
            Model: "Alexa",
            Sensitivity: 1
          A2DServer: {
            useA2D: false,
            stopCommand: "stop",
            useYouTube: false,
            youtubeCommand: "youtube",
            displayResponse: true
          recipes: [ "with-MMM-TelegramBot.js" ],
          NPMCheck: {
            useChecker: true,
            delay: 10 * 60 * 1000,
            useAlert: true
      And then the results of my aplay and a record commands :
      **** Liste des Périphériques Matériels PLAYBACK ****
      carte 0: b1 [bcm2835 HDMI 1], périphérique 0: bcm2835 HDMI 1 [bcm2835 HDMI 1]
        Sous-périphériques: 4/4
        Sous-périphérique #0: subdevice #0
        Sous-périphérique #1: subdevice #1
        Sous-périphérique #2: subdevice #2
        Sous-périphérique #3: subdevice #3
      carte 1: Headphones [bcm2835 Headphones], périphérique 0: bcm2835 Headphones [bcm2835 Headphones]
      **** Liste des Périphériques Matériels CAPTURE ****
      carte 2: AK5371 [AK5371], périphérique 0: USB Audio [USB Audio]
        Sous-périphériques: 1/1
      Do you see anything that could be the cause the cause of my problem? I’m not sure of the mic name in the micConfig …
      Thanks a lot !
      Tom
      crazylegsC 1 Reply Last reply
      • crazylegsC
        crazylegs @Tom_LabHIdouille
        @tom_labhidouille In your micConfig block you have:
        device: “plughw:2”,
        I think you could try this instead:
        device: “plughw:2,0”,
        Tom_LabHIdouilleT 1 Reply Last reply
        • Tom_LabHIdouilleT
          Tom_LabHIdouille @crazylegs
          @crazylegs Hello crazylegs, thanks for your help, i try this way !
          Up : It doesn’t work anymore.
          When I launch a mic test in the console, the microphone works perfectly.
          How can I know if the module is working ? I mean, if nothing happens when I say the magic word, it might be beacause the module is not working, instead of the microphone ?
