    Is it possible to change the CSS layout at a certain time? (Dark Mode)
    11 Posts 6 Posters 5.0k Views 6 Watching
      mopedmann
      Hey everyone,
      is it possible to change the CSS layout at a certain time?
      At the moment I use the Bright UI from Piranha1605.
      However, in the evening this is too bright and I would like to change to the Dark UI from Piranha1605.
      I would be very pleased to receive an answer.
      With kind regards
      mopedmann
        sdetweil @mopedmann
        @mopedmann there is no api to do that, but I can imagine a node helper swapping custom.css files and causing a page reload…
        • F Offline
          Foxy25
          Hi
          maybe it is possible to write a script that rename the used .css in another filename (from custom.css to Custom.1) an after that, rename an other .css to custom.css. Packed this in an cronjob an you have a change of the .css files. After the rename routine restart the mirror…
          Not the elegant way, but it can work’s.
          Another Idea: Is ist possible to dimm the Display via a cronjob ?
          Grettings Torsten
            mopedmann
            Hi @sdetweil @Foxy25
            thanks a lot for the quick and great answers!
            However, I’m a total beginner in programming and am shambling through previous solutions on the forum to implement something in the same way.
            So if someone has time and desire to develop a dark mode/css switch for the Magic Mrror this would be great.
            KamiSchamiK F 2 Replies Last reply Reply Quote 0
            • KamiSchamiK Offline
              KamiSchami @mopedmann
              @mopedmann
              … otherwise you can also have the display dimmed temporarily
              Real programmers never work 9 to 5. If they are around at 9 AM, it's because they were up all night.
              • F Offline
                Foxy25 @mopedmann
                @mopedmann
                Its not that hard as it seems.
                A handfull of code that you have to write.
                A good task to learn a bit about bash programming under linux.
                Try the fist step, it would be helpful for the future…
                Greetings Torsten
                • E Offline
                  ember1205
                  This is an interesting idea, and I found this write-up that I thought was interesting.
                  https://labs.tadigital.com/index.php/2020/04/10/night-and-day-switch-using-css-variables/
                    mopedmann
                    Thank you for all the ideas and advice. I will report when I have made first progress
                    With kind regards
                    mopedman
                    • Piranha1605P Offline
                      Piranha1605
                      I hope this help.
                      https://github.com/Piranha1605/MMM-CSSswitch
                        mopedmann @Foxy25
                        Hey everyone,
                        yesterday I have implemented the idea of Foxy25 and it works great.
                        @foxy25 said in Is it possible to change the CSS layout at a certain time? (Dark Mode):
                        Hi
                        Piranha1605’s solution looks even better and easier!
                        @piranha1605 said in Is it possible to change the CSS layout at a certain time? (Dark Mode):
                        I hope this help.
                        Thanks for the great help
                        • F Offline
                          Foxy25 @mopedmann
                          @mopedmann
                          Hi, the Css-Switcher is really the more comfortable way to do the change!
                          but, you don’t learn the basics of coding ;-)
                          Anyway, good to hear that it works in both ways.
                          Greetings Foxy
