    where can i set a colour for up/down in MMM-ServerStatus?
    20 Posts 5 Posters 4.2k Views 5 Watching
    • C Offline
      chris47803
      Thank you.
      I understand that, but where exactly do I have to enter what?
      Can you please help me?
              module: "MMM-ServerStatus",
              header: "Network Devices",   // Can be anything you want, or blank
              position: "top_right",       // Choose a position
                  hosts: [    // For example
      { ip: "192.168.2.2", name: "Fritz!Box"},
      { ip: "192.168.2.1", name: "Huelsen DC"},
      { ip: "192.168.2.5", name: "NAS 542"},
      { ip: "192.168.2.24", name: "Christian PC"},
      { ip: "192.168.2.23", name: "Marion PC"},
      { ip: "192.168.2.30", name: "Nikolai PC"},
      { ip: "192.168.2.34", name: "Wohnzimmer PC"},
      { ip: "192.168.2.29", name: "Christian NB"},
      { ip: "192.168.2.28", name: "Christian NB"},
      { ip: "192.168.2.37", name: "Nikolai NB"},
      { ip: "192.168.2.44", name: "Magic Mirror"},
      { ip: "192.168.2.27", name: "Christian A40"},
      { ip: "192.168.2.38", name: "Christian Tab A7"},
      { ip: "192.168.2.31", name: "Nikolai Honor 20 Pro"},
      { ip: "192.168.2.36", name: "Nikolai Honor"},
      { ip: "192.168.2.25", name: "Christian HTC"},
      { ip: "192.168.2.21", name: "Marion A40"},
      { ip: "192.168.2.104", name: "Drucker Schwarz"},
      { ip: "192.168.2.110", name: "Drucker Farbe"},
      { ip: "192.168.2.41", name: "Maxico Luftbefeuchter"},
      { ip: "192.168.2.48", name: "LG TV"},
      { ip: "192.168.2.35", name: "Link2Home Balkon"},
      { ip: "192.168.2.47", name: "Link2Home Schlafzimmer-Licht"},
      { ip: "192.168.2.45", name: "Link2Home Strauch"},
      { ip: "192.168.2.20", name: "Link2Home Garage"},
      { ip: "192.168.2.43", name: "Link2Home-Rose"},
      { ip: "192.168.2.32", name: "Unbekannt"},
      { ip: "192.168.2.33", name: "Unbekannt"},
      { ip: "192.168.2.50", name: "Unbekannt"},
      { ip: "192.168.2.40", name: "Unbekannt"},
      { ip: "192.168.2.39", name: "Unbekannt"},
      { ip: "192.168.2.46", name: "Unbekannt"},
      { ip: "192.168.2.26", name: "Unbekannt"}
        sdetweil @chris47803
        @chris47803 anywhere inside the config:{} section of the module.
        before or after the list of hosts.
        read the ‘how to add modules’ link in my signature below
        • C Offline
          chris47803
          Many thanks for your response. But I can program badly in English and even worse. If I put it this way, Magic Mirror won’t start anymore.
                  upColor: "green",
            @chris47803 do
            cd ~/MagicMirror
            npm run config:check
            report the error…
            • C Offline
              chris47803
              [13.03.2021 15:34.45.242] [INFO] Checking file… /home/pi/MagicMirror/config/ config.js
              [13.03.2021 15:34.45.360] [ERROR] Your configuration file contains syntax errors :(
              [13.03.2021 15:34.45.363] [ERROR] Line 182 col 2 Parsing error: Unexpected token ]
                @chris47803 said in where can i set a colour for up/down in MMM-ServerStatus?:
                so, what is on line 181?
                • C Offline
                  chris47803
                  On line ist ]
                  its the end from modules: [
                  • C Offline
                    chris47803
                    Magic Mirror will now start again. But no color is displayed
                            header: "MagicMirror status",   // Can be anything you want, or blank
                            upColor: "green",
                    [13.03.2021 16:08.46.280] [INFO] Checking file… /home/pi/MagicMirror/config/config.js
                    [13.03.2021 16:08.46.501] [INFO] Your configuration file doesn’t contain syntax errors :)
                      @chris47803 how about adding downColor: “red”,
                      i don’t know anything about the module myself…
                        @chris47803 the module uses a template and does this
                        {% for host in pingResults %}
                        			{% if host.isAlive %}
                        				<span style="color: {{ config.upColor }};" class="fas fa-{{ config.upSymbol }}"></span> {{ host.name }} {{ config.upText }}
                        			{% else %}
                        				<span style="color: {{ config.downColor }};" class="fas fa-{{ config.downSymbol }}"></span> {{ host.name }} {{ config.downText }}
                        			{% endif %}
                        			<br />
                        		{% endfor %}
