    Electron install dificulties
    14 Posts 3 Posters 4.0k Views 3 Watching
    • MissingxtensionM Offline
      Missingxtension
      npm install fails because of npm not installed…fixed that from another forum. installed npm manually
      first an pi4, but I its too slow and it should work with any linux.
      So now I am running on virtual box x86 raspbian latest, then switched to vmware pro 15.
      THey all have the same problem
      Then npm start or npm run start
      > magicmirror@2.14.0 start
      sh: 1: ./node_modules/.bin/electron: not found
      npm ERR! code 127
      npm ERR! path /home/pi/MagicMirror
      npm ERR! command failed
      npm ERR! command sh -c DISPLAY="${DISPLAY:=:0}" ./node_modules/.bin/electron js/electron.js
      /rant
      Having all kinds of install problems from the very beginning. squashing errors all left and right from different forums. But magicmirrors forum has been useless.
      I am sure everyone being able to register and post on this forum is quite capable of copy and paste commands from chromium. But the forum seems intent on not really helping anyone. They just say ohh suffer a little and read.
      That is the common mantra, Ive read that over and over again since I started with BSD had to partition (slice) by hand, then build a xorg config file from scratch. Then compile kernel modules to run binary blob drivers just to get compiz to run and enjoy woflstein enemy territory.
      But this is obviously not working, electron is no longer supported on 32 bit system and the nature of repos is that you have all kids of dependency errors from having to rely on dependencies…
      So telling people to get support from electron is not happening
      # Clone the Quick Start repository
      $ git clone https://github.com/electron/electron-quick-start
      # Go into the repository
      $ cd electron-quick-start
      # Install the dependencies and run
      $ npm install && npm start
        sdetweil @Missingxtension
        @missingxtension nice…
        i have worked with a couple other people that have had similar problems, and have opened an issue with node,
        https://github.com/nodejs/help/issues/3277
        as they are reporting 32 bit on an x86_64 system …
        then electron install gets all messed up…
        i fixed my installer to handle this problem…
        see https://github.com/sdetweil/MagicMirror_scripts
        rapid support (hours/days) support cycle from electron or node is unlikely… electron has over 1000 issues…
          Missingxtension
          @sdetweil said in Electron install dificulties:
          I already went to your github script and no luck. I also had to sudo apt-get install sh for some weird reason and that got me a little further along.
          I do keep snapshots at key point and finally I ran your script again and that was what made it work. Although initially it just keep loading multiple MM instances.
          But that got sorted out now!!! I got a full magic mirror install.
          Thank you very much!! You give me some valuable information Mainly I know i am not crazy and you put my mind at ease. Well at least a little less crazy:face_with_raised_eyebrow:
          Ill try to post the screenshot of the multiple instances. Luckily I am handy with the alt+f4 keys.
            @missingxtension said in Electron install dificulties:
            i would like to see that
            MissingxtensionM 1 Reply Last reply Reply Quote 0
              Missingxtension @sdetweil
              https://ibb.co/2cQ8Cfy
              alt text
              • lavolp3L Offline
                lavolp3 Module Developer
                Sorry but a very inappropriate rant.
                You are trying to run this on a virtual machine and are blaming this forum that it’s not working due to the incompatibility of electron with certain systems.
                Have you checked other posts on this forum?
                How long has it taken Sam to respond to you? And actually trying to help
                How to troubleshoot modules
                MMM-soccer v2, MMM-AVStock
                  Missingxtension @lavolp3
                  @lavolp3
                  1. No! and yes! Started having problems on a pi4. But that was way too slow, and no snapshots. That is where the virtual machine came in. For trouble shooting and configuration. After all the hardware is not relevant to magicmirror. I have had a virtual windows xp (caps went out, 16bit drivers, sp2 breaks system) running for over 10 years on vmware no problems, the techs that calibrate and update the equipment its operating never even notice. Until it restarts to the vmware logo. The vm is so much faster, the limits of xp still apply like memory and core count.
                  2. Yes, I am a certified forum stalker. Like most people who work on this kinds of projects. I always custom flash my routers, root my phones, and even have a z3x to save time. But I am a newbie to this
                  3. Sam was incredibly fast. Its very much appreciated.
                    @missingxtension so, you said you fixed the multiple instances issue… what did u do to fix that?
                      shutdown -r now
                      I did a reboot. After that the menus are gone from the window manager, even for chromium. That seems to stop the multiple instances, otherwise it just keeps loading them over and over again.
                        @missingxtension can u do
                        pm2 status
                        and show the results
                          https://ibb.co/YDkDZzn
                          alt text
                          After a restart the window decorations are gone ( I think they are still called that). Then only one instance starts.
                          While I was preparing this response, it eventually stopped loading instances.
                            @missingxtension the pm2 status column w the little curly cue is number of restarts.so pm2 thinks it failed…
                            can u do
                            pm2 stop all
                            pm2 logs --lines =100
                            and
                            grep start ~/MagicMirror/package.json
                              stop all wasn’t necessary
                              I had already killed the MM instances. But I can reinstall MM from a fresh if you need me to.
                              https://pastebin.com/embed_js/Mq8en42t
                              marked as spam by akismet
                              grep output
                              	"start": "./run-start.sh $1",
                              https://pastebin.com/3LwH3ZPv MM out log
                                @missingxtension so, pm2’s job is to start and keep running the processes it manages.
                                chromium is not supposed to ‘exit’, altho it does on 2nd thru nth, when it opens a page in an existing browser…
                                the question is why did the 1st instance end…
                                did u change the package,json after install?
                                do this
                                pm2 delete 0
                                then run the fixuppm2 script from my scripts site… last entry
                                this will recreate the pm2 entry
