    MMM-Scoreboard, screen all black
    11 Posts 4 Posters 4.7k Views 4 Watching
    • C Offline
      carlslylike1
      I added MMM Scoreboard, My screen shows all black. Not the “error config file” screen black, just plain black. Not frozen.
      I’ve added apps before with no issue. I even tried to copy-paste the “sample configuration” in the file - just in case my preferred configuration was flawed - but the same black screen.
      Anyone familiar with this?
        sdetweil @carlslylike1
        @carlslylike1
        so in the window where u start mm,
        npm start
        or
        pm2,
        what are the messages we could examine?
        • C Offline
          carlslylike1 @sdetweil
          @sdetweil Screen all black when I add the default MMM-Scoreboard to config. Message flagged as spam so I’ll have to break it up
          Here is the message from pm2_MagicMirror
          08:40:06: This is Geany 1.33.
          08:40:06: File /home/pi/MagicMirror/modules/default/weather/weather.js opened(1).
          **08:40:06: Setting Spaces indentation mode for /home/pi/MagicMirror/config/config.js.
          08:40:06: Setting indentation width to 2
          08:40:06: File /home/pi/MagicMirror/config/config.js opened(2).
          8:40:06: Setting Spaces indentation mode for /home/pi/MagicMirror/modules/MMM-MyScoreboard/node_helper.js.
          08:40:06: Setting indentation width to 2 for /home/pi/MagicMirror/modules/MMM-MyScoreboard/node_helper.js.
          08:40:06: Setting Spaces indentation mode for /home/pi/MagicMirror/modules/MMM-MyScoreboard/node_helper.js.
          08:40:06: File /home/pi/MagicMirror/modules/MMM-MyScoreboard/node_helper.js opened(3).
          08:40:06: Setting Spaces indentation mode for /home/pi/MagicMirror/installers/pm2_MagicMirror.json.
          08:40:06: Setting indentation width to 2 for /home/pi/MagicMirror/installers/pm2_MagicMirror.json.
          08:40:06: File /home/pi/MagicMirror/installers/pm2_MagicMirror.json opened(4).**
            @carlslylike1 weird, never seen anything produce a message about the json file
            do
            pm2 logs --lines=50
            • C Offline
              @sdetweil ok so lots of junk in here.
              I should mention this is the FUNCTIONAL version (no MMM-Scoreboard code in config file - and everything is working as before I attempted to add it)
              [1] via signal [SIGINT]
              PM2 | 2021-04-09T08:38:31: PM2 log: App [MagicMirror:0] starting in -fork mode-
                @carlslylike1 ok, stop mm…
                pm2 stop all
                then clear the log
                pm2 flush
                u MAY need to check and disable the calendar logging
                in config.js
                logLevel: ["INFO", "LOG", "WARN", "ERROR"],
                then start MM again
                pm2 start 0
                • C Offline
                  @sdetweil just going to get rid of the scoreboard app. Never had these issues with any others and don’t want it to mess up what was functional previously.
                  Thank you for the help
                  • lavolp3L Offline
                    lavolp3 Module Developer @carlslylike1
                    @carlslylike1 Next time, try to provide the config entry and the two modules around it so we can debug it.
                    Also, look into the link in my signature for troubleshooting advice.
                    My first troubleshooting action would be
                    npm run config:check
                    and send the resuls here if you don’t understand yourself
                    How to troubleshoot modules
                    MMM-soccer v2, MMM-AVStock
                    C 1 Reply Last reply Reply Quote 2
                    • C Offline
                      carlslylike1 @lavolp3
                      @lavolp3 I did try, and the forum said “spam detected” and wouldn’t post it. I do appreciate the quick responses and the help
                      • lavolp3L Offline
                        @carlslylike1 Interesting. Never experienced this while posting config extracts.
                        • BKeyportB Offline
                          BKeyport Module Developer @lavolp3
                          @lavolp3 FYI, it helps to code quote it. (```)
