    MMM-RemoteControl: Can't see remote in MM and can't access
    3 Posts 2 Posters 812 Views 2 Watching
    • C
      CheapDad
      Noob here. I believe I’ve correctly installed the module. However, I cannot see it in the MM and I cannot access the MM from another device on my internal network. Here’s the key entries in my config.js:
      The network settings:
      config = {
      	address: '0.0.0.0', 	// Address to listen on, can be:
      	port: 8080,
      	basePath: "/", 	// The URL path where MagicMirror is hosted. If you are using a Reverse proxy
      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.42", "::ffff:192.168.0.50"], 	// Set [] to allow all IP addresses
      And for the module itself:
          module: 'MMM-Remote-Control',
          // uncomment the following line to show the URL of the remote control on the mirror
          // position: 'bottom_left',
          // you can hide this module afterwards from the remote control itself
              customCommand: {},  // Optional, See "Using Custom Commands" below
              showModuleApiMenu: true, // Optional, Enable the Module Controls menu
              secureEndpoints: true, // Optional, See API/README.md
              // uncomment any of the lines below if you're gonna use it
              // customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
              // apiKey: "", // Optional, See API/README.md for details
              // classes: {} // Optional, See "Custom Classes" below
        sdetweil @CheapDad
        @cheapdad turn off the ipWhitelist, which is currently only allowing from localhost (127.0.0.1)
        ipWhitelist:[]
        C 1 Reply Last reply
        • C
          CheapDad @sdetweil
          @sdetweil That did it; thank you! Interestingly, I still don’t see a control menu on the mirror. I can access it through another device, though, so that’s good.
