    Can't edit compliments.js
    12 Posts 3 Posters 3.0k Views 3 Watching
      mayfield @thgmirror
      @thgmirror said in Can't edit compliments.js:
      Hi @mayfield,
      Most of the times, commas are missing (here at least after the line with the position). Use the builtin function to check if it is valid…I use a website where you can enter the whole content of your config.js:
      https://esprima.org/demo/validate.html
      Greetings
      Thomas
      It was a comma on the position line lol Its working again thanks for the tip
        mayfield @sdetweil
        @sdetweil said in Can't edit compliments.js:
        @mayfield
        ah mmos…
        then u have to run the command inside the docker container where mm is installed
        OK cheers I’ll do some reading and thanks everyone for the help much appreciated
