    Can't edit compliments.js
    12 Posts 3 Posters 4.6k Views 3 Watching
      mayfield @sdetweil
      @sdetweil said in Can't edit compliments.js:
      @mayfield no. but.
      don’t edit the source file. copy module setting to config.js… in this case the compliments object
      in general, never edit the source files. the system is designed to take what is in config.js first.
      Ok thanks for the tip I will do that 👍
        mayfield
        I’ve been reading through the documentation from here https://docs.magicmirror.builders/modules/compliments.html#configuration-options
        Each time I add this to the config it stops working I’m obviously missing something.
                        module: "compliments",
                        position: "lower_third"
                        compliments: {
                        anytime: [
                                "Hey Wren!"
                        morning: [
                                "blah blah blah",
                                "blah blah blah",
                                "blah blah blah"
                        afternoon: [
                                "blah blah blah",
                                "Yblah blah blah",
                                "blah blah blah"
                        evening: [
                                "blah blah blah",
                                "blah blah blah",
                                "blah blah blah"
                        "....-01-01": [
                                "Happy new year!"
        thgmirrorT 1 Reply Last reply
        • thgmirrorT
          thgmirror @mayfield
          Hi @mayfield,
          Most of the times, commas are missing (here at least after the line with the position). Use the builtin function to check if it is valid…I use a website where you can enter the whole content of your config.js:
          https://esprima.org/demo/validate.html
          Greetings
          Thomas
          S M 2 Replies Last reply
            sdetweil @thgmirror
            @thgmirror the built-in checker is
            from the MagicMirror folder do
            npm run config:check
            thgmirrorT M 2 Replies Last reply
            • thgmirrorT
              thgmirror @sdetweil
              @sdetweil I know:-)
                sdetweil @thgmirror
                @thgmirror typically ‘unexpected token’ means the line before was missing a trailing comma
                  mayfield @sdetweil
                  Yes this was going to be another question I wanted to ask as that doesn’t work on mine and I’m not sure why yet
                  I followed this site to flash a SD card https://github.com/guysoft/MagicMirrorOS
                  and when I run that I get this I guess I need to install that
                  alt text
                    sdetweil @mayfield
                    @mayfield
                    ah mmos…
                    then u have to run the command inside the docker container where mm is installed
                    M 1 Reply Last reply
                      mayfield @thgmirror
                      @thgmirror said in Can't edit compliments.js:
                      Hi @mayfield,
                      Greetings
                      Thomas
                      It was a comma on the position line lol Its working again thanks for the tip
                        mayfield @sdetweil
                        @mayfield
                        ah mmos…
                        OK cheers I’ll do some reading and thanks everyone for the help much appreciated
