    Can't edit compliments.js
    12 Posts 3 Posters 3.2k Views 3 Watching
      mayfield
      Hello everyone
      I’ve been using magic mirror for a few days now and have had no trouble editing config.js. I’ve been able to change the calendar from US to Australia, the news feed and the weather to my location here in Fawkner.
      However each time I change the compliments.js and use ctrl o to save and then ctrl x to exit and then reboot the rpi no changes have been saved.
      I have tried sudo nano compliments.js and still no luck. Do I need to stop the magicmirror service in order to edit the compliments.js?
      What I want to do is add a few compliments and remove a couple.
        sdetweil @mayfield
        @mayfield no. but.
        don’t edit the source file. copy module setting to config.js… in this case the compliments object
        in general, never edit the source files. the system is designed to take what is in config.js first.
          mayfield @sdetweil
          @sdetweil said in Can't edit compliments.js:
          @mayfield no. but.
          Ok thanks for the tip I will do that 👍
            mayfield
            I’ve been reading through the documentation from here https://docs.magicmirror.builders/modules/compliments.html#configuration-options
            Each time I add this to the config it stops working I’m obviously missing something.
                            module: "compliments",
                            position: "lower_third"
                            compliments: {
                            anytime: [
                                    "Hey Wren!"
                            morning: [
                                    "blah blah blah",
                                    "blah blah blah",
                                    "blah blah blah"
                            afternoon: [
                                    "blah blah blah",
                                    "Yblah blah blah",
                                    "blah blah blah"
                            evening: [
                                    "blah blah blah",
                                    "blah blah blah",
                                    "blah blah blah"
                            "....-01-01": [
                                    "Happy new year!"
            thgmirrorT 1 Reply Last reply Reply Quote 0
            • thgmirrorT Offline
              thgmirror @mayfield
              Hi @mayfield,
              Most of the times, commas are missing (here at least after the line with the position). Use the builtin function to check if it is valid…I use a website where you can enter the whole content of your config.js:
              https://esprima.org/demo/validate.html
              Greetings
              Thomas
                sdetweil @thgmirror
                @thgmirror the built-in checker is
                from the MagicMirror folder do
                npm run config:check
                thgmirrorT M 2 Replies Last reply Reply Quote 0
                  thgmirror @sdetweil
                  @sdetweil I know:-)
                    sdetweil @thgmirror
                    @thgmirror typically ‘unexpected token’ means the line before was missing a trailing comma
                      mayfield @sdetweil
                      Yes this was going to be another question I wanted to ask as that doesn’t work on mine and I’m not sure why yet
                      I followed this site to flash a SD card https://github.com/guysoft/MagicMirrorOS
                      and when I run that I get this I guess I need to install that
                      alt text
                        sdetweil @mayfield
                        @mayfield
                        ah mmos…
                        then u have to run the command inside the docker container where mm is installed
