    Electron vs Magic Mirror Puzzle
    3 Posts 2 Posters 615 Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      So I did a direct copy paste of MMM-NewsFeedTicker from a MM where it works flawlessly over to big screen MM where it doesn’t work flawlessly.
      If I comment out the NewsFeedTicker in config.js everything is good. Put back in service and it just pops up a black screen that I assume is some alternative terminal, Electron.
      The only difference is that the MM that works is running older version of MM as I have not updated it.
        sdetweil @ankonaskiff17
        @ankonaskiff17 so you may have to run npm install again in the module folder. and check the console for missing modules…
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          ankonaskiff17 @sdetweil
          @sdetweil That wa the ticket. Ran npm install on that module, said it installed 2 components which I took as a positive sign. Un-commented the module in config.js and running well.
