    PIR sensor in combination with IR transmitter
    Scheduled Pinned Locked Moved Unsolved General Discussion
    pir sensorhdmi-cecir transmitter
    4 Posts 2 Posters 1.0k Views 2 Watching
    • E Offline
      erwindenboer
      Hello,
      For my first Magic Mirror, I want to use an old TV that I have lying around. My TV uses Simplelink (CEC), so commands can be sent to my TV to turn on. Unfortunately, it can’t turn off using Simplelink (CEC). To solve this, I want to use an IR led. I also have an PIR sensor. So what I want is when a person moves in front of the PIR sensor, a signal will be transmitted via the IR led to my TV to turn on. After a certain amount of time, I want the Raspberry Pi to signal to the TV to turn off. I couldn’t find a module which does this. I hope someone has an idea how to realize this idea.
      Kind regards.
        sdetweil @erwindenboer
        @erwindenboer you don’t need a module to do this. or anything MagicMirror
        most of the pir support is in python, and I’m sure u can find python support for sending the led signal.
        then is wait and launch the shutdown command
        you should be able to build this as a bash script
        #!/bin/bash
        python command to read the pir
        python command to send the led signal
        sleep n seconds
        shutdown now -h
        if you use pm2 to start mm, you can also use it to start this bash script
        reference
        pir
        https://www.deviceplus.com/raspberry-pi/using-pir-motion-sensors-with-the-raspberry-pi-and-python/
        send ir
        https://www.raspberrypi.org/forums/viewtopic.php?t=79978
          @erwindenboer also, make sure there is a good delay on the pir sensor. you’d be amazed how easy it is to trip the durned thing.
          • E Offline
            erwindenboer
            @sdetweil Thanks for your fast reply. I will test this out next week. Then I will come back to you to let you know if I have more questions or if I solved it. I really appreciate it!
