    unexpected token
    3 Posts 2 Posters 639 Views 2 Watching
      adamhrastich
      ‘’'* Magic Mirror Config Sample
      • By Michael Teeuw https://michaelteeuw.nl
      • MIT Licensed.
      • For more information on how you can configure this file
      • see https://docs.magicmirror.builders/getting-started/configuration.html#general
      • and https://docs.magicmirror.builders/modules/configuration.html
        let config = {
        address: “localhost”, // Address to listen on, can be:
        // - “localhost”, “127.0.0.1”, “::1” to listen on loopback interface
        // - “0.0.0.0”, “::” to listen on any interface
        // Default, when address config is left out or empty, is “localhost”
        port: 8080,
        basePath: “/”, // The URL path where MagicMirror is hosted. If you are using a Reverse proxy
        ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”], // Set [] to allow all IP addresses
        // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.1.5”],
        // [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “::ffff:192.168.3.0/28”],
        useHttps: false, // Support HTTPS or not, default “false” will use HTTP
        httpsPrivateKey: “”, // HTTPS private key path, only require when useHttps is true
        httpsCertificate: “”, // HTTPS Certificate path, only require when useHttps is true
        language: “en”,
        locale: “en-US”,
        logLevel: [“INFO”, “LOG”, “WARN”, “ERROR”], // Add “DEBUG” for even more logging
        timeFormat: 12,
        units: “imperial”,
        // serverOnly: true/false/“local” ,
        // starts serveronly and then starts chrome browser
        // true, force serveronly mode, because you want to… no UI on this device
        module: “alert”,
        module: “updatenotification”,
        position: “top_bar”
        module: “clock”,
        position: “top_left”
        module: “calendar”,
        header: “US Holidays”,
        position: “top_left”,
        symbol: “calendar-check”,
        url: “webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics” }
        module: “compliments”,
        position: “lower_third”
        module: “weather”,
        position: “top_right”,
        weatherProvider: “openweathermap”,
        type: “current”,
        locationID: “5262634”, //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
        apiKey: “c2647e77b86f90ed7922d3cb499204d0”
        module: “weather”,
        header: “Weather Forecast”,
        type: “forecast”,
        module: “newsfeed”,
        position: “bottom_bar”,
        feeds: [
        title: “New York Times”,
        url: “https://rss.nytimes.com/services/xml/rss/nyt/HomePage.xml”
        showSourceTitle: true,
        showPublishDate: true,
        broadcastNewsFeeds: true,
        broadcastNewsUpdates: true
      if (typeof module !== “undefined”) {module.exports = config;}
        sdetweil @adamhrastich
        @adamhrastich unexpected token, usually means the line before the reported line is missing a trailing comma
          adamhrastich @sdetweil
          i think i found it thank you
