    Clearing Custom CSS warnings from editor,
    10 Posts 2 Posters 1.6k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      I use VS Code as my editor and it is fine at recognizing standard CSS items of which there must be thousands but I see in some of these modules developers create custom CSS items and VS Code flags them, I think I saw same when I was using other editors early on.
      Code throws up a warning flag on the custom items but I’m at a loss as to how to clear them. I imagine it i similar to writing an engineering heavy document where I just say “add to dictionary” and resolves problem. Do these code editors have a similar way of clearing the warning. I’ve tried to figure out in VS Code but so far have not been successful so just ignoring
        sdetweil @ankonaskiff17
        @ankonaskiff17 no idea, do u have any examples of the warning? I don’t use vscode usually
          @ankonaskiff17 i don’t see any warnings on main.css
          i see two on my webform.css from MMM-Config, but they are good warnings, empty selector…
          don’t see any on MMM-Config.css
          my custom.css is empty
          ankonaskiff17A 1 Reply Last reply Reply Quote 0
            ankonaskiff17 @sdetweil
            @sdetweil It’s in the ClendarExt2
            .CX2 { /* default values which are used frequently or dependently */
              row-min-width: 100px;
              row-max-width: 500px;
              column-min-width: 300px;
              column-max-width: 400px;
              font-size: 12px;
            Unknown property: ‘row-min-width’, same with all 4
              @ankonaskiff17 i would have to assume those are CalExt2 classes, which VC wouldn’t know about…
              the author would have to provide a vscode extension to do that
                @ankonaskiff17 and just as a reminder, in this case at least, the author is no longer present on the forums, and has stopped supporting his modules.
                no other user has taken over support or development.
                  @sdetweil Is there any type of calendar module to fill that niche. Was about the most convoluted way imaginable to essentially get my Samsung phone calendar to post items on to my MM.
                  Samsung Calendar app---->Google Calendar---->CalExt2—>Visual on MM
                    @ankonaskiff17 sorry no idea. I use the default calendar module.
                    I use Samsung phone, connected to google
                    and the Google url in cal url, works easy peasy. nothing hard to do.
                    ankonaskiff17A 1 Reply Last reply Reply Quote 1
                      @sdetweil Thanks. MM I am making now doesn’t need any person specific calendar.
                      So you are pulling that link you can get from Google calendar and plugging it in where the US Holidays ical link is in the default module setting?
                        @ankonaskiff17 yes. and I have multiple calendars and do the same, add another url
