    Format/Delete Sunset & Sunrise Time
    4 Posts 2 Posters 1.3k Views 2 Watching
    • ankonaskiff17A Offline
      ankonaskiff17
      Not sure if this is a custom.css question or a config.js question.
      In the default Clock module you have the option to show sun time and moon time. By default they are off but I have set to true.
      I am scaling up the modules for big TV and had to set .region.left a lot wider than however it translates on to the big screen because the showSunTimes and showMoonTimes were starting to text wrap although that might not be quite the term used. I would like to do away with the circled portion of the sunset and I assume sunrise time I have circled in the clock module.
      I ran it down to this block in Developer Tools but not sure how to tackle.
      I want to keep the sunrise and sunset times but don’t really care about the time UNTIL sunrise or sunset. I would probably get rid of the percent of full moon value too but imagine I just change verbiage similar to how to approach the sun question
      On top of that it will allow me to recover some of the middle region I gave up when I widened .region.left.
        sdetweil @ankonaskiff17
        @ankonaskiff17 given the way its coded, text in an icon, I don’t know if U can get back the space…
        but… css allows you to target/select both classes (starts with . ) and elements (do NOT start with dot)
        here is a cheat sheet
        https://www.w3schools.com/cssref/css_selectors.asp
        but I think u can do this all with classes
        .modulename  i.fa-sun-o  {
           /*    i 'think' the only thing u can do is hide the text  */
          color: black;
        maybe using the ::before
        https://www.w3schools.com/cssref/sel_before.asp
        I don’t know if this syntax will work…
        .modulename  .fa-sun-o i::before {
            content: "";
        // from my MMM-Config web form css
        // and u read the right to left
        these are all targeting html elements, no classes
        a legend, whose parent is a fieldset following a span
        targeting the legend
        span ~ fieldset >legend {
            color: #333 !important;
        here is a legend, whose parent is a fieldset whose parent is a li, ul, div
        div > ul > li > fieldset >legend {
        ankonaskiff17A 1 Reply Last reply Reply Quote 0
          ankonaskiff17 @sdetweil
          @sdetweil fa is font awesome?
            @ankonaskiff17 i think so
