MMM-MirrorMirrorOnTheWall - Alexa voice control to hide/show modules and display text/images
That’s the error I always get also. I have the the contents of the folder zipped not the folder I left the keys as MagicMirror also and have index.handler selected.
@savage_gr1nd yeah, but it requires a physical pushbutton. I’m using AlexaPi with my own wake word, so I can activate Alexa by saying “Mirror mirror”.
@joanaz ahhhh. That sucks. I’m running wake word also. I just liked the idea of not having to run it in terminal. Then run mirror. Would have made rebooting simple and flawless. Lol
@joanaz @savage_gr1nd I had my certs both as MagicMirror and other names, made sure everything in the code is correct every time I changed anything.
It just wont take it.
I will go around this another way, I’m starting to lose interest in the whole tts concept and will go with something simpler using text :)
@savage_gr1nd you can setup AlexaPi to run automatically after reboot
@Journeytojah @zman3 see whether this thread helps you.
https://github.com/lorenwest/node-config/issues/275 -
@joanaz nice. I’ll look at switching over after work.
You need to work on the YouTube functions lol -
I tried all that last time you posted it with the exeption of process.env.NODE_CONFIG_DIR=‘/var/task/config’;
@joanaz been there, tried it… nothing worked…
@zman3 no, that’s not the point, he uses the config library, we don’t. They mentioned some good points, such as “OSX makes node_modules readable only by the user so AWS cannot read it”, so you need to check the permission of your node_modules folder. And also make sure the node_modules inside the zip file is not empty.
